The third era of solid state stereo receivers from Harman Kardon centered around the 330A and 330B and the clones made by Roland and Soundcraftman:
This thread is a guide to those models, their specs, and pointers to schematics and restoration threads for each. If you have additional information on any of these models, send me a private message and I'll get your info inserted into the right spot in the top posts.
I'm calling this era of HK stereo receivers the "minimalist" era... because that kinda fits their looks. If someone has a better name for this ear, let me know.
This era is identified by the change from the mostly-black, all-dark face plates of the prior "Nocturne" era to a very simple, silver-and-black, plain-lettering look.
Model numbers were numeric digits (e.g. 330) instead of the prior era's written-out numbers (e.g. “Three Thirty”).
I lump the models in the era in three waves of models:
The 330B was wildly popular and HK rebadged some 330A's as 330B's... which leads to a lot of confusion. There are also a good number of factory variants on the which-board-in-which-model category.
The 330C, the end of what I'm calling the "minimalist" era, is kind of a bridge to the follow-on Twin Powered era. It is more like a single-power-supply HK 430, but I've lumped the 330C in this grouping or era to keep search and model confusion to a minimum.
There are two models of "330", the 330i and the 330vi, which came much, much later and have nothing to do with the 330A, 330B or 330C... so the 330i and 330vi are not covered here.
Initial waves of models:
Second wave of models:
Final wave:
There are also a number of 330AB models re-badged by other brands:
Other Harman Kardon solid state receiver guides:
- Initial wave of follow-ons from the Nocturnes. This includes the 230A and the 330 (all numbers, no trailing letter). These were manufactured in the USA.
- The second wave started with the 330A, continued with the 330B... and then the 330A's came back to life as 330B B-2 series. These were manufactured in Japan and Taiwan.
- The final wave in this era is just the 330C.
- Harman Kardon 330A
- Harman Kardon 330B (also known as "B-1 series")
- Harman Kardon 330B B-2 series (re-badged 330A)
Final wave:
- Stratophonic (SR-300, SR-300B, SR-400, SR-400B, SR-600, SR-600B, SR-900, SR-900B)
- Nocturne (Seven Twenty 720, Two Ten 210, Two Hundred 200, Five Twenty 520, Five Thirty 530, Two Thirty 230, Three Thirty 330, Eight Twenty 820)
- 330 minimalist (330, 330A, 330B, 330C)
- Twin Powered (430, 530, 630, 730, 930)
