The second era of solid state receivers from Harman Kardon were (what I call) the Nocturne series.
This thread is a guide to those models, their specs, and pointers to schematics and restoration threads for each. If you have additional information on any of these models, send me a private message and I'll get your info inserted into the right spot in the top posts.
The Nocturne era mostly looked different from their predecessors, the Stratophonic receivers, in that the Nocturnes had mostly black faces. They also moved to mostly silicon transistors.
This era is most-easily identified by the mostly-black, all-dark face plates, grey or silver-capped black knobs, and grey or white lettering. Most of these really only show up when they are powered on and the lamps inside start shining.
Model numbers were written-out numbers (e.g. “Seven Twenty”) instead of just numeric digits (e.g. “720”).
There appear to have been three waves of models in the Nocturne era:
Again, these were written-out model numbers, so “Two Thirty” and “Three Thirty”. This distinction becomes important when compared to the next era.
Initial waves of models:
Second wave of models:
Final wave of models:
Other Harman Kardon solid state receiver guides:
- The initial wave included the 720, 210, and 200.
- The second wave only had the 520 and 530.
- The final wave included the 230, the 330 (written out and not numeric digits), and then 820.
- Harman Kardon Two Thirty
- Harman Kardon Three Thirty (this is not the HK 330)
- Harman Kardon Eight Twenty
- Stratophonic (SR-300, SR-300B, SR-400, SR-400B, SR-600, SR-600B, SR-900, SR-900B)
- Nocturne (Seven Twenty 720, Two Ten 210, Two Hundred 200, Five Twenty 520, Five Thirty 530, Two Thirty 230, Three Thirty 330, Eight Twenty 820)
- 330 minimalist (330, 330A, 330B, 330C)
- Twin Powered (430, 530, 630, 730, 930)
