Fred DuBuron
my plan is to use wires soldered on to female "spring-loaded" pin sockets that are going to be routed outside the back of the test mule speakers. The whole affair out the back of the speakers will be shrink-wrapped This way I can slide the capacitor leads into the pin sockets with minimal effort. I plan to run each set up for 30-40 hours before I sit down and start to "listen".I would recommend putting the crossover outside the cabinet and adding alligator clips to each cap so you can quickly swap them back and forth.
I have a few test tracks in mind including this puppy.
The disk is called "Digital Domain: A Demonstration Soundtrack CD".
Look for disk item number: 9 60303-2
It is described as "Digital Domain: A Demonstration Soundtrack CD music that contains a single disc with 29 songs.
This disc is divided into 3 sections.
Sections 1 and 2 are DDD.
• Section 1 is sound effects (helicopters, ocean sounds, lions, and more),
• Section 2 is a series of test tones
• Section 3 is instrumental music
The disc was originally was released on Feb 15, 1983, on the Elektra label
It is out of print and is only in stereo... They can be found on eBay for under $7
If you dare chase down a copy of this disk (they are still out there and very reasonable).
The very first track is called "The Digital Domain" and is 7:24 minutes long.
It starts off by sucking the quietness out of the room and then wonderful sounds slowly float into the room.
I won't give it away, but be warned: "It will blow up any speakers that are not up to the task" or if you are careless with the volumn knob (SEE WARNING ON PICTURE #3).
