I've had good luck with a few 2way speakers on there sides with the tweeters to the outside also for imaging and sound stage.Drivers mounted horizontally usually have a wider soundstage. This is why center channel speakers are placed horizontally.
I think we have to clarify the difference between "soundstage" and "imaging". Soundstage is about the distance like width, depth and height. Imaging is about direction and separation as it refers to the ability of said audio gear to place and position individual sounds/instruments accurately within that soundstage.
I've noticed that some companies still make large floor speakers with 12-15" woofers... JBL and Cerwin Vega to name a couple. Generally speaking, can a tower speaker with two 6" woofers make as much bass sound and feel as one 12" woofer ?
This is correct. In real life the effective diameter of a 12" or 6" (or any other size) driver is not 12" or 6" because cone surround decreases that and every surround has not the same width, but if the effective diameters really are 12" and 6", then a 12" driver has exactly 4 times the effective area than a 6" driver or 2 times the effective area of a 8,5" driver (if there is such a size).In short - No.
Cone area of 2 x 6" speakers is about 56.6 square inches.
Cone area of 1 x 12" speaker is about 113 square inches.
The 2 6" speakers will have to move twice as far in the same amount of time to match the 12" speaker with no overshoot.
That's why large diameter drivers tend to present a bass sound that is deep and relaxed.
So you're saying that multiple smaller drivers can correspond one bigger driver in some rooms but not in all rooms. Why is that?The smaller drivers might be able to produce the frequency, but not with enough room-filling dynamics to accurately reproduce the dynamics of some music, in some rooms. So, it depends (as someone above mentioned) a bit on the space you’re filling,
If we’re discussing drivers and SPLs the distance from a driver (larger room) being inverse to SPL you will need larger driver(s), more drivers, or more excursion to project further into a room. The smaller driver can produce the frequency, but without additional excursion or more drivers to make up for the smaller area they will not be able to reach the SPL for that space. Much like how a headphone driver, very small, can produce ample bass right next to your ears but not in open space.
If that was the case then they would only use 1 woofer with the mid/tweet. Two woofers placed horizontally increase dispersion/soundstage for a wider sweet spot.
Also that is not the reason for the tweeter and the mid aligned vertically.
I use to own this center channel speaker. The dialogue was clear with no comb filtering. Its dispersion/sound stage pattern was wider then those with just 2 woofers.
Yes, it is the reason for the mid and tweeter to be vertical. That DOES improve off-axis horizontal response, greatly.
The reason two woofers are used, is that it creates what's called a D'Appolito array- which SOMEWHAT mitigates the asymmetry of the dispersion, if the woofer was just on one side. With the right spacing, the comb filtering can be mitigated enough, so that a reasonably wide sound field can be had, with reasonable uniformity. The crossover frequencies on these, are also as low, between woofer and mid, as is possible without damaging the midrange, usually, to try and reduce the effect of the comb filtering, as well.
In any case- any horizontal woofer array- or any really wide driver trying to produce midrange frequencies- is an inherent soundstaging and dispersion compromise, way more than any vertical array. Vertical dispersion is much less needed (a narrower vertical dispersion can actually be HELPFUL- as it reduces floor and ceiling reflections), but uniform and wide horizontal dispersion is paramount, for a speaker to actually be able to create the illusion of soundstage, in a room...
Regards,
Gordon.
Exactly. And- speaking of lots of small drivers instead of a few big ones- that's the same principle that line arrays work on- very wide horizontal dispersion, VERY NARROW vertical dispersion. Makes intelligibility a LOT easier to achieve, without all those floor and ceiling bounces- especially in the horrid acoustic environments of many public spaces.The Infinity Emit tweeter comes to mind, very wide dispersion with limited vertical, very important these be at ear level.
I’d think that smaller woofers, owing to their lower mass, would give a punchier bass since they could react more closely to the signal.
The line arrays I use frequently (EAW Radius 208L), we wind up having to actually TOE THEM IN a bit, they have so much horizontal dispersion. Sounds awesome once it is done, though. A few degrees is all it takes. We actually have special sling/harnesses we attach to the arrays, to hold them at the proper toe-in. What a difference THAT made. Much better sound overall, even beyond the imaging and soundstaging improvement (and yes, we DO tune our stage array setups for best soundstaging. We are indeed that nuts.)
Regards,
Gordon.
Yes, but in general a car like a 3 cylinder Fiests (or for that matter a V12 Ferrari) with tiny pistons (a woofer is like a piston) would be able to rev higher and more quickly than the large V8 in your Mustang example.A 3 cylinder Fiesta has lower mass than a Mustang GT. Which is quicker? A simplistic analogy but with a point.
IME large sensitive woofers with strong motors can react to the signal well enough to give excellent midrange response and very punchy bass in the proper enclosure. I'm talking about the Altec 515, 414, 416 and 406-8C.
No, not necessarily. While two 8.5" may have the same cone area and even displacement, there will be points where the two sound waves come together and reinforce each other adding an additional 3 dB. There will also be areas where they cancel each other. The idea is to select the arrangement that lets these happen at the desired frequency.If the linear excursion is the same in all those drivers, then the maximum displacement volume of one 12" driver will be the same as four 6" drivers or two 8,5" drivers and thus the maximum sound pressure level will be the same. This is independent of the room size. Bass tuning is disregarded here.
There are also big woofers with low mass and small woofers with high mass. And even if smaller woofers usually have lower moving mass, their magnets usually are weaker. Magnetic flux density multiplied by voice coil length forms a force factor which drives the woofer. In addition to force factor and moving mass, also compliance, voice coil dc resistance and mechanical resistance comprise a so called Q factor which determines the woofer behaviour.I’d think that smaller woofers, owing to their lower mass, would give a punchier bass since they could react more closely to the signal.
