Thank you Pete B.
Generally speaking, do most folks get their bass from a subwoofer rather than larger drivers in their speakers... or the opposite ?
It depends on your goals. If you requirement is to play pipe organ (16Hz), synth, or home theater (HT) effects
then you probably need a large and capable subwoofer. Otherwise, the lowest note on a grand piano is about
28 Hz and as people have noted there are reasonably sized systems that will reach that low. My favorite that
easily play 28 Hz at room shaking levels is the PSB Stratus Gold, 10" woofer in a big box, port tuned to 28 Hz.
I've compared these to a pair of Advents and the PSB s will play about 9 dB louder, fairly cleanly, than the
sealed Large Advents.
Some huge floor standers with a pair of big woofers act almost as good as a sub, not always.
If I were designing a similar 3-way to the PSB s I'd use a 12" woofer just for a bit more headroom, in fact I have
done it in the past. Sorry, the friend I did it for took the not so good picture:
I've never documented this build that was done in the 1990s but I spoke to the friend who has them and he says
that he will never sell them. They're built in Madisound premade boxes. We copied the PSB crossover, with the
air core woofer inductor replaced with a low DCR Sledgehammer also from Madisound to make up for the less
efficient 12" woofer substitute and we put Lpads on the mid and tweeter to also compensate:
