Does adding weight to headshell increase tonearm effective mass?
What does "g" mean? Not grams for sure.
Yeah, I'm starting to wonder myself now that the numbers are sinking in.
If I understand how cartridge/stylus compliance works (and in addition to this thread, I've been reading all over the net), the higher the tonearm mass, the lower the compliance should be for the cartridge - and vice versa, all because of inertia.
Here's a quote from another thread that runs similar to explaining compliance of the AT95E.
the at95e in stock form may have changed..as over this side of the pond..it was often considered to track best somewhere between 1.75 - 2.0 gm in a medium mass arm..ie around the 10.5 - 12gm effective mass range..
i'm pretty sure that the at110e has a higher compliance than the at95e if you were looking for a better match mechanically with a lighter arm..although sadly the cartridge is now less widely available than the 95e..(which is a shame as it is better than the stock at95e in a few sonic areas)
Normally we just call it compliance units (cu). But in reality it´s the inverse of a spring coefficient. so it will become mm/N, or microm/mN
:yikes: He's blinding me with science! :thumbsup:
Speaking of science, would either of you be able to please explain what the AT representative means by 'softer compliance' when he refers to the AT100 being 14g.
I'm having trouble understanding why a lighter tracking, softer compliance stylus would have a higher number than the 95.
Thanks!
Thanks!
Pay no heed to what this dimwit at AT is telling you.
OEM recommended tracking force (RTF) is a strong indication of a cartridge's compliance. High compliance cartridges typically have lower RTFs. High RTF indicates low compliance and medium compliance cartridges are medium RTFers. Tonearms have light, medium or heavy effective mass (eM). High compliance cartridges are happiest with light eM tonearms and low compliance likes heavy eM. Mediums are just plain boring, they like mediums most. It's not all that confusing once you understand. Of course I may be :crazy:.
Thank you.
So is it relatively safe to assume that there's no compliance issue with using that AT95E on the Yamaha 11g effective mass tonearm?
I'm still trying to figure out why my parents are having tracking problems on an accurately set-up TT with clean NOS records.
If I can rule out the cartridge/tonearm combo, I can start to concentrate elsewhere. Not an easy task, doing troubleshooting from 2000 miles away.
Thank you.
Not a compliance issue. The Rega RB 251 comes in at 10.5 grams of mass, and the AT cartridges work fine on it.
My guess is that a digital scale was not used to set tracking force. When the arm was floated to get the 0 tracking weight, the ring may not have been set to 0. Or someone mis read the scale when setting the tracking force.
Either that, or there is a bit of fluff on the stylus, even though the records were supposed to be clean.
The only other options is that the table is not level. Or the arm bearings are binding. Or the arm cue platform is not going down all the way, and contacting the tone arm sometimes.
Regards
Mister Pig
Regards
Mister Pig
Thank you Mr. Pig, I appreciate it.
I'll walk dad through a re-setup again, to make sure it's correctly done.
My gut says it's a record that needs to be cleaned or brushed again, but they say it happens randomly, and not at any specific places.
Like I've said before, I'm sure I could figure it out in 20 minutes if I was there to do it. LOL
If the problem is random my money is on accumulated groove debris. Even clean NOS records have groove debris. It's like dust.
Of course your parents probably miss you and could be messing with you to generate a visit home. :thumbsup:
And there it is. You called it, Mr. Pig.
After talking to dad yesterday, and going through a full re-setup, I had him pull the tonearm out into the open space between the platter and where it parks, and lightly tap up or down to see if it was moving freely.
Nope. Sticky.
Now if you guys remember, and I don't really expect you to, when I got that P-20 last summer, I noted in that thread about it that I was surprised that the tonearm was floaty, since stickiness was an issue with my 751 and a few others I've read about here.
I took some pics, and emailed him a how-to to resolve it by just ever-so-slightly loosening that inner retaining pivot screw like how I fixed mine.
So he called me today to walk him through the process, but with his little jeweler's screwdriver, he can't get enough torque on it, and those screws are in there tight - I remember mine.
So we're currently waiting for him to find a more suitable screwdriver.
I don't get it though. I thoroughly checked that table before it left, and the tonearm floated so well that I decided not to pop that cover off and loosen it just a degree. Man I wish I had. I'm disappointed that they're not instantly enjoying the TT, especially since I knew it might be tough to convince them to reaccept older technology after being around newer for so long.
The way I had it packed, there was no way for any impact to affect the tonearm. I had it off its rest, and secured (without the headshell or counterweight) down to the inside where the platter would go. Then there were stiff foam blocks strategically gripping the plinth and well above/below to support the closed top and bottom of that box (similar to how it would have been packed when new). Then, once that box was secure, it was placed inside another, oversized, double-walled box with 4 inches of peanuts in every direction - with the platter suspended inside those peanuts at the bottom. You could jump on any side of that outer box, and not disturb the inner - I totally overdid it to avert any disaster.
So I'm 1000% sure it arrived in the exact condition it left here. So what could've caused this sudden stiffening?
The only two things I can think of is possibly microscopic dirt picked up by the pivot from moving the tonearm down considerably lower than it normally rides - or - the sudden drastic change in climate. It's 80-something here, but it's below freezing there. Could that be it?
IDK, but at least we now know what's wrong, and as soon as he finds a better screwdriver and calls me back, I'm sure we'll have it operating properly. I even offered to send him the one I used on mine.
I should've just backed that screw out a degree anyway before I sent it. :( I feel bad that my parents aren't having as much fun yet as we do listening to their new records.
Smart effective people, help.
I am trying to bypass the spring-loaded tracking force dial on my Thorens TD 160, but the counterweight and fine-tuner at the very end only max out at 1g. And I have an Excel ES70EX4 cartridge that tracks at 1.5-2g. There were more than the usual tracking errors due to footfall on my wood floors, at 1g, so I have added 0.5g of Blutac on top of the headshell, making my gauge read 1.5g. Am I causing any potential problems? It sounds great and there is much less sensitivity to footfall.
redeplaya, Re bearing adjustment: I've never adjusted one, but I'm willing to bet that the larger/outer slotted part is internally threaded and performs a locking function to hold the adjustment from changing. I'm showing my age now, but if you ever adjusted valves on a pushrod engine, same deal. If the "lock-nut" isn't super tight, in some cases you can adjust the screw-it would be quite stiff. But if my hunch is right, you'll need to break the outer part loose (CCW) to enable adjustment. And if it's like a valve adjuster, re-tightening the outer part may actually loosen the adjustment a little from the play in the threads themselves, requiring trial and error method.
OTOH, I may be full of malarkey!
You're absolutely correct. Thank you for your good intentioned assistance.
Not too long after that thread, I decided to make a thread devoted to fixing some of the common problems that arise on this line of TTs after 35+ years of use/neglect.
Below is an excerpt from that thread explaining the whole repair process.
And here's a link to the thread in its entirety.
http://www.audiokarma.org/forums/in...350-p-450-p-550-p-750-p-751-p-10-p-20.729001/
Thanks again. :thumbsup:
Yamaha P-(X)50 Series DIY Maintenance​
Tonearm
  • Bearing Lubrication
Tools required
  • Slot-head mini-screwdriver
  • Fine sewing needle
  • Q-tips
  • Paper towel
  • Mild cleaning solution (Windex)
  • Light machine or clipper oil
Over the course of the last 35 years or so, the upper bearings of the tonearm on the P-(X)50 series turntables have had a tendency to have the original grease harden or get sticky. This causes the tonearm to not balance properly during setup, and ultimately renders any Vertical Tracking Force weight readings inaccurate. It can also play a significant role in mistracking when playing a record. If the tonearm doesn't 'float' in balance, and tends to stick up or down when nudged, it most likely needs to have the bearings cleaned and relubricated.
Removing the tonearm, cleaning the bearing races, relubricating, and reinstalling is a fairly straightforward process, but it is a bit of a challenge. It requires concentration and a delicate touch. That said, a typical DIYer should have no problem completing the process successfully. I would recommend reading through the instructions below a time or two to familiarize yourself with the entire process before attempting it on your own table.
Again, I'll reiterate, this is an 'at your own risk', YMMV type of maintenance. Please take that into consideration before attempting.
Disassembly​
Start by unplugging the turntable and putting it on a clean, flat, well-lit work surface with the right side toward you. Remove the headshell and counterweight. Place your left hand on the platter with the spindle between your two middle fingers and place the tonearm between your thumb and forefinger as shown in the photo below.
This grip on the tonearm allows for good leverage and stability without stressing it too far in any particular direction.
Next, locate the silver plastic disk that covers the bearing screw on the pivot of the tonearm.
With the fine point of the sewing needle, insert it at the gap between the metal base of the pivot and the plastic disk.
Lightly pry the disk out by its edge, being cautious not to slip or mar the finish.
Lock the tonearm in its rest, and repeat the disk removal procedure on the opposite side.
The disks have a type of thin adhesive tape on their backs which hold them in place, and should be stored in a safe location, adhesive side up, until it is time to replace them.
Underneath the disks, you'll see the upper bearing screws (silver metal, center) and the locknut (brass, outer).
Insert the mini-screwdriver into the center bearing screw and attempt to back it out. It may be tight, and suddenly 'pop', so be careful. If the screw refuses to turn, the locknut may be preventing it. If you have a special tool that will grip the two slots on the outer locknut, I'd suggest using that to loosen it. If not, and you're lucky like I was with mine, insert the mini-screwdriver into one of the slots of the locknut, and turn it counterclockwise and it will loosen its grip enough to then allow removal of the center screw.
Remove the center screw and locknut completely, and repeat this procedure for the other side. As you are removing the opposite side, be very careful with the tonearm. As it comes loose, it is very vulnerable to damage - especially the wires.
Next, gently lift the tonearm out of its pivot and roll it over to one side or the other being extra cautious of the tonearm wires (moving it back, behind the pivot, may help). There should be just enough extra wire coming through the base of the pivot for this to be possible.
If you feel any hesitation from the wires, stop, reposition the tonearm in the pivot, and replace the pivot screws enough to securely hold it in place - you may need to go inside through the bottom cover of the TT and see if the wires are catching on anything.
If it is going as planned, lay the tonearm down on its rest with one side of the inner bearing accessible, and use the rest lock to lock it in place.
Cleaning and Lubrication​
Add a drop of the light oil to the bearing race and let it soak for a minute or so. Take a piece of the paper towel and roll it into a small point. Insert the point of the paper towel into the center of the race and twirl it around to clean out any of the old gunk that's in there. Repeat this procedure, adding another drop of oil until you are satisfied that it is as clean as it's going to get. With another piece of paper towel, clean the outer area of the bearing, including that black circle that surrounds it. Get all of this area as clean as it can be.
Unlock the tonearm, and roll it in the opposite direction to reveal the other bearing race. Repeat the above procedure, cleaning the inner bearing race, and outer area.
At this point, it is the perfect time to take a couple of those q-tips and mild cleanser and clean the rest of the pivot, paying special attention to the areas that are permanently obscured by the tonearm when it's in place. Also clean the inner area of the pivot where the screws were.
I found that pulling the cotton out a bit from the stick of the q-tip and twisting it tight gave a 'cleaning point' that was sturdy enough to 'screw' through the inner screw-holes to clean out any debris in there too.
Now, place a fresh drop of oil on both bearing races, and re-lock the tonearm in the rest.
Clean both bearing screws and locknuts with a drop of oil and a piece of paper towel so they're nice and shiny, and free of debris.
Reassembly​
On both sides of the pivot, reinstall the bearing screws so that their points are flush with the inside surface of the pivot. Replace the tonearm into the pivot, making sure the wires feed effortlessly back through their hole. Holding the tonearm exactly in its proper place, slowly screw in the bearing screws until you feel them take hold in the bearing races.
Center the tonearm in the pivot by adjusting the screws in and out, starting with backing one out a little, first, then screwing in the opposite side to match. It's easy enough to eyeball the centering, but if you have a feeler gauge, all the better. Do not over-tighten either screw.
Once you've got it centered, replace the counterweight and headshell. With the thumb and forefinger of one hand, grasp the pivot directly at the bearing screws, and grasp the tonearm with the other hand. Gently wiggle to see if it is secure in its bearing. If it is wobbly, turn in each screw just a degree or so at a time, until it no longer wobbles, but is still floaty and free moving on its axis. This may take a few attempts.
Afterward, balance the tonearm, and see if it free floats like it should. Bear in mind that this is a light tonearm, so some minor resistance may be induced by the rigidity of the wires.
Once you're satisfied that it is operating as it should, replace the locknuts. Only screw them down to the point where they just become snug against the inner surface of the pivot. Avoid turning the inner screw during this process (possibly easier said than done).
Re-test the tonearm for 'floatiness' - some delicate adjustment of the screws may be required to perfect it.
If it is floating properly, replace the plastic disks, rebalance the tonearm, and check the alignment of the cartridge.
Crack open a well deserved cold one...
You're done! ;)
Click To Return To Table Of Contents
