I don't see it being electro magnetic being flesh and bone
That's where you get into my kind of physics.
Friction is absolutely electromagnetic.
But it's at the atomic level.
Generally, it's like this.
Every atom of everything you can see, or not, has a nucleus and electrons.
We'll borrow this image from Northwestern to help convey the idea.
Though throughout the 'Atomic Age' it was conveyed to the general public like the image on the left - a lot of MCM designs used that idea - Jetsons and George Nelson atomic clocks - it was actually only sort of correct.
The electrons of an atom actually form more of a cloud(shell) around the nucleus, like the image on the right. We know where the shell is for each level of electrons. Finding the electron in that shell has been a bit more challenging - has a bit to do with Heisenberg's Uncertainty Principle. And in the case of that cloud, MCM designs would never have looked as cool as they did.
Hydrogen being one proton, and one electron is first in the periodic table (PT). Its one electron floats around the nucleus in a shell. Oxygen, being 8, has 8 electrons. Two of those electrons float around on an inner shell, and the other six, float around on a second shell farther out. The higher we go up the periodic table, the more electrons and shells we get. There's an order to it though. The first shell always tries to have 2 electrons in it, the second wants 8, and so on. Hydrogen only has one electron, but it tries to fill its empty electron by creating a bond by borrowing an electron - in the case of another hydrogen it forms a hydrogen bond H2 - or in the case of water, H2O the two electrons of the paired hydrogen fill the two empty spaces in the oxygen's shell - they share the electrons, creating a bond. The more electrons they share, the stronger the bond.
Ok enough of the boring nerdy stuff.
Now that we've explained atoms and the electron shells, here's how it applies to friction and heat:
When your hands are rubbing together to create heat, they're actually not really touching. Nor are you touching your chair when you're sitting. The electrons have a negative charge and are repelling each other, like trying to push the same poles of two bar magnets together.
When the electron clouds of the atoms of your hands, it this case, encounter each other, they squash in a bit because they are trying to repel each other. As you move your hands, the clouds are constantly squashing in repulsion and then springing back. This mechanical energy of the electron clouds squashing and expanding creates heat as a by-product. Spread over the enormous amounts on atoms on each hand, there's enough heat from this mechanical energy to be sensed by nerve endings which then trigger electrical impulses to inform the brain that it feels heat - and that's where you get into biology, and I start to drift from my realm of science. LOL
