Gusten, I don't think we are so much concerned about the tonearm resonant frequency as we are about the cantilever resonant frequency. I'll mention it in a minute but in the mean time - 3 grams are a lot. To counter those 3 grams and stay with the same VTF we'll need to move back the counterweight by X millimetres. So, we've added 3 grams at the front, and pulled back X millimeters to counter them and what we've ended up with, is a tonearm with a different effective mass. It's 'heavier' now - if you will.
Notice VTF may still be your desired (just an example) 1.5 grams, but the moment of inertia of the tonearm (effective mass) had changed. You've changed it by adding those 3 grams and countering them using the counter weight. Think about what the tip of the stylus 'sees' now after that modification as the load and burden it needs to shift for every modulation. It's gotten heavier now - more mass - more inertia - more resistance. That affects the 'performance' or the tonearm's characteristics.
If you had one of those very low EM tonearms, say a Black Widow with 3.5 grams of effective mass, you've now transformed it into a 4 - 4.5 grams EM tonearm. I seriously doubt it's a major modification to the SQ but as far as the cantilever resonant frequency goes, where we're dealing with dynamic forces, it is not the mass that counts but the moment of inertia.
In other words - it's very possible that while VTF stays the same after adding those 3 extra grams and countring the extra mass with the counter weight, we'll cause a downshift in the cantilever's resonant frequency and it's no longer in the golden range. If what you are saying was as simple as it sounds and there was no difference between mass and effective mass (to my understanding of your argument) - there would be no need for the resonant calculators and there would be no difference in performance between a black widow and an Akos Lustre. Please explain.
Hi,
Don't know if this has been covered. I haven't read all the posts. The compliance of the AT95 is 6.5cu @ 100Hz. The 10Hz cu (for the calculator) is 15.
neo
If you zero balance the arm and turn off the antiskate, the slightest breath of air or gentle touch should send the arm all the way across the platter, and full up or down.
If more weight is on "Rey" then the fulcrum point needs to be moved to be balanced (your not evening it out equally), I don't see that in your drawings or mention of it. Moving the fulcrum could be loosely translated as resonance changing??? It may be that it's still balanced but the pivot point is changed???
I'm starting to get the 1000 mile stare thinking about this stuff
Ok, I've crudely drawn this scenario to try to better understand inertia and the forces we're dealing with.
Figure 1)
For the sake of argument, stick figure rey (a little deformed in the first one) is standing with a very lightweight board resting on his shoulders. The board is perfectly balanced at the center, so the weight on his shoulders is negligible. If he were to jump up at this moment, he would experience almost no resistance since the weight of the balanced board is almost none and would be easy to offset.
Figure 2)
rey now has a block weighing 2 resting just behind his shoulders on that same balanced board. For the sake of argument, he feels the full 2 of the weight on his shoulders. If he were to jump, he would be met by the resistance of the weight of the 2.
Figure 3)
rey again is standing under the board. This time the board has a weight of 100 on it at his shoulders and an equal weight on the other side of the fulcrum. The board is still balanced so he feels no weight at his shoulders, but this time, if rey were to jump, he would be required to move the 100 weight with him. Though the mass is balanced with a counterweight, it's still there. It is not the same as Figure 1. Staticly, yes, but dynamically, no. Newton's first law - object at rest, stays at rest.... Therefore, it would be more difficult for rey to jump in this case because there is mass present that isn't present in Figure 1.
Figure 4)
Same set up as 3, except now we have added an additional 2 weight to the one side of the balance. Standing still, rey will feel only the 2 weight on his shoulders, much like in Figure 2. But if he was to jump, he would be met with not only the forces that apply in figure three, but also the additional weight in Figure 2.
Back to the compliance requirements of the AT95E, if the tonearm riding above it isn't providing enough static resistance (Figure 1) to prevent it from jumping, it could easily jump. With the addition of the 2 weight, it only needs to overcome the weight of the 2 (Figure 2).
But, if the tonearm was heavier, it would be harder for it to jump because it would have to overcome the static mass (Figure 3) even though it's still in perfect balance. Now with the addition of a 2 weight into this same scenario offsetting the balance and placing the weight of 2 on the AT95E, when it felt the desire to jump, not only would it be resisted by the weight of the 2, but also the mass of the combined system (Figure 4).
Since we may be determining that the AT95E needs a little balanced mass on its shoulders to prevent it from jumping, and since we know that the Yamaha tonearm may be too light to provide that additional mass, as best I can understand, adding a headshell weight, balancing, then adding proper VTF, should work like I've described above.
Right?
One way is to think of the phenomena is that somewhere in the low freq range we will have a resonance. Above that res the arm should be perfectly still and read the grooves. Below that res the arm should follow the record, and not read the grooves. If we add mass the needle will read the grooves at a lower freq, it will then easier skip, as it will also read warps and possibly also footfalls.
Poor figure rey will hurt his shoulders more in fig 4 than in fig 3 and more in fig 3 than in 2 if he jumps at the same force.
Other than that all of the figures illustrate static forces. In order for those figures to demonstrate dynamic forces, figure rey
would have to transform to a shaking Stevens, have wobbly knees, ride a pongo stick and do it on a treadmill while the swing board
travels with him - all at the same time.
The tonearm mass is not designed to prevent the stylus from skipping or jumping - it's a by product of the tonearm design which
is spec'ed to work with an expected range of carts at a certain range of weights (masses) with a certain range of compliances.
In the above figures, it would probably manifest best as a 46.8 weight designed for figure rey, sugar Alice or breadcrum George
and for them only.
