Does adding weight to headshell increase tonearm effective mass?
There is a fine line between adding mass and weight....the result of which adds noise at the point of contact with the vinyl. Adjustment of tracking and of tone arm downward angle might be considered.
I suck at math...
tell me if I am in compliance
Technics SL-1200mk2 w/ stock tonearm>Orsonic anti-vibration headshell>Soundsmith Carmen cart
It sounds great to me, no innergroove distortion, no skips tracking at 1.7gr
I don't know what any of it "weighs"
I think it's high time we complain to the companies that produce this ridiculous format for giving it to us and then telling us "here it is, we just recorded it for you, you figure it out!" :)
Just curious, does the table in question use a damped counterweight? I understand pretty well the benefits they should have, but I've rarely been happy with tone arms that use them. I also wonder if the compliance of the things changes over the years. It's always amazed me that nobody uses a similar thing at the head shell. Put a small mass on the head shell, floating on tiny bits of Sorbothane, and watch resonances disappear. Still audible mistracking shouldn't be an issue unless something basic is wrong. The worst problems to fix are when something is basically OK, but screws up every now and then.
He's got it listed at x10, not x100. Since it's the only site that actually gives that number, it's the only one I could go with.
That's not the frequency. All compliance numbers are X 10-6 cm/dyne. Look at the first 2 calculators here. 10Hz is specified. Many Japanese mfg. rate compliance at 100Hz.
http://www.vinylengine.com/cartridge_database_tools.php
We've figured out 10Hz cu for many AT models. The 120/440/150 are 10cu @100Hz = 18cu @10hz.
The 95 is a stiffer suspension and max VTF is 2.5g. The 10Hz cu = 15.
There is no single multiplier for conversion.
There is no cart today with 10Hz cu of 6.5. It wouldn't track. I own a 95. Although I don't use the stock stylus, it works great in arms up to about 17g eff mass, maybe more. You'll have no problem with an 11g arm. You could try adding that extra weight and see if you like it better.
neo
I suck at math...
Ron, here's my setup (with weights):
- SL-1200 arm
- Modded Denon DL-103 - 15.3g and has compliance of a rock
- Orsonic AV-11 headshell - 9.5g
- KAB 17g auxiliary weight with a lot of wraps of lead tape (weight unknown) around it to get the arm to balance
Overall this boat anchor setup sounds pretty damn good!
Those Orsonic headshells are pure magic Mike, worth every penny. I dig the tuning fork look also!!! I don't use any additional weights so hopefully someone can run the numbers and see if I am in compliance. Stuart hooked me up with a digital stylus scale so I don't even look at the counterweight. This thing is so accurate I bet it can weigh a dust spec LOL
Rey: Not quite correct. In case three little Rey would actually feel en effective/equivalent mass of 200 and 202 in case four, if little Rey would try to move the arrangement.
Greetings from Munich!
Manfred / lini
Manfred / lini
Oops! Yeah, I see that now. Forgot about the other side. LOL
So you're saying my little drawing makes sense and would, at least at a rudimentary level, explain the difference between a low mass tonearm and a higher mass tonearm?
Ps: Again, I really appreciate all the input you guys have laid out here in this thread to help understand the physics of this. Like it was mentioned earlier, this has really been a learning experience - even if it's almost caused brains to explode! LOL
reydelaplaya
We need to get together and get bombed and contemplate human existence. It's easier to justify the blank stare when we contemplate the Universe and beyond, something like tonearm mass seems so mundane in the grand scheme of things but in a way, it's every bit as important
:beerchug:
I quit everything almost 16 years ago, but after the whirlwind of formulas and physics and stick drawings this thread has turned into, I'm starting to wonder if a couple beers wouldn't help wrap my head around it all! LOL
My bet would be that the new cartridge is a different height than the old one. And the arm lift of the cue device as not been adjusted, or it is not going all the way down. Some time the arm might contact it, especially if there is a warp. Casing it to skip.
Another possibility is the tracking weight is too high and its bottoming out, or too light and skipping.
The AT cartridge is not terribly stiff cartridge, and AT typically rates their compliance at 100 hertz, and not 10hertz. So the static compliance of 20 dyne is closer to what we would normally measure. Which is not a huge mismatch with the arm.
I personally doubt its a compliance problem. Something else is going on.
Regards
Mister Pig
Regards
Mister Pig
The cartridge it had on it when I got it was an AT3450 - and I'd bet it was the original 'Yamaha' to the table.
They seem to be identical in size and design, only different in specs and model numbers. It really shouldn't be rubbing the cue-track, especially since that cue-track drops way down when disengaged.
I gave the whole TT a good cleaning/regreasing/restore, and workout before I sent it off with that new cartridge to make sure it would be as 'plug n play' as possible once it arrived at their house. Sure there was some reassembly and setup involved, and even though I packed it like our TT packing thread would have me do, there is the possibility that something that was working, now isn't.
And as far as not being a mismatch to the tonearm, that's what I thought too.
I need to get them to take a couple pictures while its playing so I can see if I see anything - like that cue-track.
We'll get it figured out. Thank you for jumping into the mud here with us Mr. Pig!
Love my one Orsonic headshell. I need to get another or two. The only issue I have with it is that the mounting area is a bit thick for some screw sets that I use. Sweet design and nicely turned out.
Then there is the theory that increased mass leads to increased friction which results in the stylus picking up unwanted noise.....
Friction is misunderstood as well. Adding mass does not increase friction, it increases downforce. a 100 pound block of steel, sitting on a steel floor takes 70 pounds of force to keep it sliding horizontal (after moment of motion has passed. Its friction coefficient is 0.7. a 10 pound block of steel sitting on a steel floor takes 7 pounds of force to keep it moving, it friction coefficient is 0.7.
Velocity does not increase friction, but frequency does. In general (not all cases) as frequency goes up, friction goes down.
Put a 25lb weight on a sled and pull it. Then add 5lbs and pull it. It's fine in place but when you pull the weight laterally, you feel the extra mass by virtue of extra friction right? The friction is the extra lateral mass in the record groove as it's pulled. Balancing does not change lateral friction, weight dictates that (I think???)
no, friction doesn't change the energy needed to move extra mass has, ie inertia.
(...) So you're saying my little drawing makes sense and would, at least at a rudimentary level, explain the difference between a low mass tonearm and a higher mass tonearm? (...)
Pretty much yes to that - however, for the intended purpose it might have made more sense to place the board (made of Noweighium ;)) on top of little Reys head and the load on top of that in the drawing, to make it more clear that he's at the same distance to the pivot as the load and counterload and thus "feels" 100 % of these.
Manfred / lini
