Preach, brother. We have a double sided 3M we use at work to anchor electronic devices to trays. You have to employ violence to get it loose. This is "hang upside down and shake it for a day" strong.
I know 3M makes a thin almost clean double side tape and they also make tape that has foam in the center of two sticky sides. There is that other company that you can use to stick things with that has a tab if you want to break the two surfaces free. You pull on the tab stretching the tape making it break from the surfaces with out damaging them.
Ohhh this is good info, some of that tape would work great for some of the vintage tube amps with the paper thin faceplates overlaying a metal plate. They always seem to flex out a little with the hoods off. I’ve used the double sided scotch tape and it works for a while.
Yea I put up plastic on the windows...... The Frost King Tape is really good but too good and hard to get off the trim, I think that's why 3M is still in the game, their tape holds great but it's also easy to pull off.
