Probably just the usual problem. I.e., you'll probably just need to replace the two capacitors C2 and C3, which are responsible for phase shifting the operation voltage for the second winding of the SM100-1 motor. These are located on the usual little board, which you can see for example there (bottom illustration on the left side):
https://www.hifi-archiv.info/Dual/528s/CS528_CS1268_02.jpg (service manual page for the 528/1268 shown, as there isn't a service manual for the 1264 on Lulabu's archive)
And if you replace C2 (0.33 µF) and C3 (68 nF), you'd best also replace C1 (10 nF), which serves as anti-sparking cap for the main switch, as it's not unlikely, that it also won't be ok anymore. Mind you, though, that all three replacement caps should at least be X2 class safety cap types, because due to C1 being in parallel to the main switch C2 and C3 also never are quite off, unless you'd pull the mains plug. Back in the day Dual typically installed Rifa (now Kemet) PME271 family metallised paper type foil caps, but nowadays you can alternatively also use metallised polypropylene (MKP) or metallised polyester (MKT) type foil caps.
Greetings from Munich!
Manfred / lini
