My first brand new turntable was a Dual 1015 in 1968. Then switched to a belt drive Pioneer PL-12D in 1973 because idler drive tables were "bad". Followed in 1978 by a direct drive Aiwa AP2200 and was where I stayed until 2005 or so.
A need for 78 RPM arose, so another Dual crossed my path - a 1010. Found it at auction and there began the compulsion to obtain more and more old turntables.
There was an older Rega/SME combo and a Kenwood "Rock" both belt drives, an assortment of Dual belt & idler drives as well as a direct drive 701, multiple Elac's, some Garrard Zero 100's and a Pioneer direct drive PL-630. Plus a smattering of other late 70's Japanese offerings.
Over a few years I disposed of (sold/traded) all of them except these and they're idler drives.
Two Dual 1009's (first generation)
A Garrard Zero 100
An Elac 10, 50H and 750 II
BSR McDonald 810
I also kept the direct drive Pioneer PL-630.
Excluding the latter (which sees little use) I've gone 360 degrees. Started with idlers - ended with idlers.
In the works is a Thorens TD124 II which shall be my last turntable purchase. And it's an idler. Or at least the secondary drive is an idler. This one will not depose the others but be used in conjunction with them.
There is no real point in my posting this except to say that maybe, in very general terms, idler driven turntables have become in vogue - enjoying a renaissance so to speak.
Personally, I just like older turntable which in my case, happen to be idlers.
