Dumb question - sorry
samwise801
AK Subscriber
But can I swap tubes in and out of, say, a pre-amplifier (in my case, a Conrad Johnson PV-12) while the unit is powered off, but still plugged in, without issue? Or is it recommended to unplug the sucker first?
I would turn the power amp off, too. You don't want a big transient or full blast noise bomb hitting your speakers.
Fair enough. But so long as everything is powered off, I'm okay "tube rolling?" I shouldn't need to unplug everything too, or otherwise take any add'l steps?
You mean while all your other equipment is powered on? Yes, if you want to switch out tubes in the preamp, turn it off and switch the tubes after about a minute, careful they may be hot, and then you can turn it on. Should be no problem doing that.
If you have to remove a cover to access the tubes, and there's any chance to touch any of the internal wiring, I would strongly suggest to unplug the preamplifier from the wall outlet.. Don't forget that tubes operate at voltages which can be lethal to humans, so unless you're an experienced tech, I would never suggest changing tubes in a unit which is plugged in. Also, you shouldn't operate the preamplifier without covers installed, for similar safety related reasons, not to mention shielding.
No need to disconnect patch cords or any other non power wiring. If the tubes are accessible without removing any covers, just shutting off the power is sufficient. Be careful to let the tubes cool down before you pull them out, it isn't good to handle hot tubes too much. (they can be damaged, and so can your hands!)
Also, before you get too obsessive over tube rolling, be aware that tube sockets can get worn out from this practice - it's better to remove and install tubes as seldom as possible to keep the sockets in top shape.
As long as you keep your fingers away from the power cord wires (and the power switch), it's OK to replace tubes in a preamp which is turned off but still plugged in. Might not be a bad idea to drain the filter caps, if you can access them.
-Adam
Awesome. Thanks everyone for the help!
Yes, I do have to remove the cover to access the tubes, but the inside is pretty sparse and the tubes aren't hard to grip firmly w/o even getting close to other components.
And thank you for the tip on not removing / installing tubes too often. I'm sure plenty of folks out there have equipment that's otherwise in great shape, but with worn / loose tube sockets. Sounds like a bummer!
Yep, I serviced some VTL amps where if you turned it upside down, the tubes would literally fall out! I managed to tighten the sockets, but that's a temporary fix, they will never be as good as before.
Hello hello everyone,
I am French, I do not speak English and I translate with Google translation and I apologize
help blog amplifier VTL 35 Triode.
After long years of service one of my 35 blocks dropped me HS output transformer.
I can not find the diagram of this VTL 35 Triode, I sent an email to https://vtl.com to ask them to help me
a photocopy of a diagram or the characteristics of the output transformer (input impedance)
they kindly replied that it was better to buy a new amplifier, commercially I find it very average ...
my VTL 35 Triode blocks. These are double push-pull, the tubes of 4. 5888 and 2. 6201 on each block.
Can you help me with information or advice?
I thank you in advance.
cordially
cordially
Measure the transformer which is still good, buy a pair of the closest thing you can find, then fine tune the amplifier to suit them. It is a moderate amount of of work, but very possible.
