I'm dragging another PM discussion into this thread. Screw it, let's make a mess! I'll go back to the beginning and put in a summary when it's done anyway.
From PM:
If you can clarify me because i don't understand some things (maby my English is bad ). Zilch said (second or third page on "PCD mettle" thread) that he had some phase issues with PCD. I found that when i make Z offset 11 cm for woofer, everything lines up. You can see it here:
http://techtalk.parts-express.com/showthread.php?215536-Flex-Your-PCD-Mettle&p=1792825#post1792825
I downloaded all files Zilch uploaded and worked with them. That is the result i got. Now, earlier Zilch wrote that offset between midbass and waveguide is 63mm (tweeter behind midbass) . PCD is showing that 11cm is dead on. I'm suspecting that PCD does have some issues.
edit: everything below was assuming the z-offset is supposed to be positive for farther from the mic, which apparently isn't true, except it seems like it is, see later posts.
Heh, I am wondering about the exact same thing right now, big time. I am getting +11.5cm for my woofer offset when using the tweeter axis for measuring/simulating (woofer 11.5cm farther away). My woofer
is deeper than the waveguide, but only a little. From what I am reading, the waveguide acoustic center is actually somewhere in the throat, but 11.5cm still looks very far.. not impossible. Now, if PCD is considering the relative z-offset as
from the mic position, it is much more believable..
How Zilch got -62mm is troubling, and I'm having trouble interpreting the conversations those guys had about it. At first I thought maybe he just ended up with a polarity inverted vs. real life, so if he had clicked to reverse the polarity before finding offset, he would have gotten -8cm or something like that. BUT, if I reverse polarity, I can't get it to match up at all, whereas with polarity as I measured, everything lines up neatly at 111.5cm for the woofer.
Tonight, I'm going to try moving the measurement axis and reloading everything, and see how that changes (or doesn't change) the z-offset I end up with in PCD.
