There's a type of dustcover hinge used on some Yamaha, Sony and probably other turntables that have a characteristic sort of failure where the "tail" of the spring eventually breaks through the plastic "web" that is supposed to retain it. The result is a complete loss of spring tension so the dustcover can no longer stay up on its own.
I've seen fixes here where what remains of the web is reinforced with a metal plate held in place with epoxy. I've tried that in the past but didn't have long-term success. Eventually the epoxy holding the plate would fail and I'd be back to "square one".
I just picked up a Sony turntable with this type of hinge and, just my luck, both hinges had failed. My previous experience made me reluctant to try the epoxy and plate repair again so I began thinking about a different approach.
Here's what I came up with. Instead of reinforcing the web I completely removed it. Then I took a 1/16" drill bit and bored a hole in both sides of the hinge at the reinforcing gusset where the hinge pin joins the top and bottom halves of the hinge. I then took a 3d finishing nail, snipped off the point and inserted it through the two holes,capturing the tail of the spring underneath the pin.
The whole repair of both hinges took maybe 15 minutes. Remove remains of web, drill holes, insert pins and re-fix the other spring tail in the bottom half of the hinge. If I do say so myself, it works perfectly.
Unfortunately, I didn't take any "before" or "during" photos. If I had this post wouldn't have been nearly so long-winded. I did tale an "after" photo of the repaired hinge. See below.
John
