The Power Output Stage Pt.2: Configuration, A Short History
Speakers. Being basically current operated devices, tubes have a distinct disadvantage in driving them, since tubes are basically voltage operated devices. This is where SS designs have a distinct advantage since they too are basically current operated devices, so the shoes and shoelaces match. For tubes to have a level playing field, they need a transformer to convert their high voltage low current nature, into the low voltage high current requirements of a speaker. But being a voltage oriented device, tubes have one other disadvantage that a transformer cannot account for: Resistance -- referred to as Plate Resistance. It can be minimized by circuit design and output stage configuration, but SS devices have such little internal resistance that they have a huge jump on tubes in this regard when the load is a speaker.
The ultimate resistance of a given amplifier design then is called its "Internal Resistance", which is the primary element in determining the Damping Factor of an amplifier. Quality vacuum tube amplifier designs will have an internal resistance of around 0.5-1.0 ohms, while SS amplifiers will often display an internal resistance of .0xx ohm, many times lower than that of conventional vacuum tube amplifiers. That is why SS amplifiers have such higher damping factors, compared to their vacuum tube brethren. So why is this important?
Let's say an amplifier has an internal resistance of 1 ohm. Sonically, using an amplifier with a 1 ohm internal resistance is effectively the same thing as using a perfect amplifier with 0 internal resistance, but placing a 1 ohm resistor between the amplifier and speaker. Besides the power loss created, there is also a loss in control of the speaker, and both increase as the resistance increases. As a basic point of understanding then, from a speaker control standpoint, any resistance (from any means) between the speaker voice coil and the generator source driving it is effectively like coupling a perfect amplifier (0 internal resistance) to the speaker voice coil through a mechanical spring.
If an amplifier with 0 internal and external resistance commands the voice coil to abruptly stop -- as in the reproduction of a single pulse for example -- it will, because the 0 impedance of the amplifier electrically shorts out the output from the voice coil that would normally be generated due to it's tendency to want to remain in motion from momentum after being excited by the pulse. So the voice coil abruptly stops in this scenario. But if there is any resistance in the circuit (including that of the voice coil itself) -- represented by the spring -- the voice coil is no longer as effectively controlled, so voice coil movement can continue on beyond that created by the original pulse. With music, this manifests itself as the speaker producing sound that was not in the original program material . The result is muddy, low definition, BUT ACCENTUATED bass response in many speakers -- because of the continued, loosely controlled motion of the speaker cone at low frequencies. No wonder then that many find SS amplifiers superior in LF performance: Not only is there typically more available power, but often, better quality of bass reproduction as well because of the lower internal resistance they afford. So how does this all relate to the ST-70? We're getting there.
Early "high "fidelity" designs (think big E H Scott radios) had but one way to operate the output stage: Triode mode. Why? They were the only tubes that existed at the time. For a vacuum tube configuration, triodes have the lowest plate resistance, and therefore, make for pretty good devices to drive a speaker. But, they aren't very efficient, so they don't produce very much power. As a result, speakers had to be large and use horn configurations to have the efficiency required to produce a usable output. Triodes also have a limited HF response as well. But then early program material didn't have much HF energy associated with it anyway. But then, technology greatly advanced the efficiency of a tube, resulting in the creation of the pentode. Pentodes can produce boatloads of power compared to triodes, and have improved HF response, but have a very high plate resistance, which ultimately makes them rather lousy for high fidelity reproduction needs all by themselves. But then, a solution was found.
Applying NFB to pentode based amplifiers offers the solution to the pentode's ills, because it effectively lowers the pentode's high plate resistance characteristic, with the amount of reduction based on the amount of feedback used (assuming it was well applied). All of a sudden then, you could have your cake, and eat it too. But of course, human beings being what we are, we argue (to this day) over which is better: Low power triode operation (with, or without NFB), or high power pentode operation with lots of NFB. We'll argue over the order of distortion products produced (low order for triodes, higher for pentodes), which triode is the best triode to use, or even if a pentode connected as a triode really is a triode! Then, Misters Keroes and Hafler showed up.
With their perfection of tapped screen operation (originally suggested by Blumlein), UltraLinear Operation was born. Their transformer company -- Acrosound -- was the first to offer it to the audio community through their first UL transformer model, the TO-300. With it, the characteristic of a pentode tube is fundamentally changed. Now, the power, efficiency, and frequency response of a pentode could be had, along with the low impedance and lower order distortion products of a triode, all in one neat package. Of course, we're still human beings. So all it really did was give us a third mode of operation to argue over
. But I digress. UL changed audio history. And while good performance was still to be had in smaller amplifiers and receivers with non-UL operation from a wave of new small power pentodes to come, UL operation (or some form of it) remained the go-to design for most (but not all) manufactures, when it came to high power high quality audio reproduction, right up to the end of the vacuum tube era.
All of this is likely old school to many in our hobby here at AK, but there are also many newbies coming into it everyday. If they get barraged with decrees from those who say you must do this or that to the output stage for good sound, but have only little understanding of basic output stage theory themselves, then they have little ability to know if a given modification is really in keeping with the audio goals they seek. Which in fact, brings us back to the ST-70. If only for those then, this provides some background as to why the output stage of the ST-70 was designed as it was, and with the next installment, what different modification configurations can potentially do to its performance.
They are up next.
Dave
