Dynaco ST-70: Base Line Testing
I'll be lurking with interest as I just rebuilt two ST-70's: one for our son and one for me. In one of them I used the Triode transformer set, and in the other I used the Bob Latino transformer set. I installed Classic Valve Design (CVD) Bias/balance Power Supply and CVD DynaMutt driver boards, but wouldn't mind upgrading/replacing the Mullard GZ34 rectifiers too.
... and waiting for a universal EFB board too. :smoke:
6 --Thanks for contributing your comments. I agree very much that full power 20 Hz runs are hardly indicative of normal use. In this case however, I ran the tests to give an indication of just how much of a compromise the single rectifier tube design is -- which is much more than that of the power transformer that so many who like to trash the design focus on. I also ran them.... well, because I did come from a band background in the 60s, where the power supply had to hold up under all manner of, er... conditions! Therefore, my default mode is to always look at (at least) the power supply with a critical eye, such that if the spec says it can perform to a given level of performance (or in this case, doesn't say that it can't), then I'll test to see if it can.
To be fair however, when this unit was produced, the specifications for the ST-70 -- like that of so many other units -- did not include ratings with both channels driven. Actually, it was very ambiguous as I implied above, never really stating either way. Only Mac and the like provided such clarity. Therefore, I'm testing the 70 against specifications that don't exist -- or do they?
I remember (and have now looked up fragments of) something that David Hafler did back when the FTC got involved in the audio performance ratings war. He took a full page ad out in a publication railing against the new regs because all of a sudden, the MK III unit became a 50 watt amplifier with a reduced power response curve, and the ST-70 effectively became an ST-40 -- with each channel rated as "20 watts RMS, with < 1% THD, 50 Hz to 10 kHz, into 4, 8, or 16 Ohms, both channels driven". Preconditioning was mandated, as were test condition of course, but I can't help but wonder if a significant portion of the ST-70's serious de-rating under the FTC's regs was due to -- you guess it, the single rectifier tube design. Remembering this little piece of history then would indicate just how severe my full power 20 Hz testing potentially is with this unit, versus what the Feds said it was capable of.
In any event, I think the rectifier tube is arguably the weakest link (and therefore, the biggest compromise) in the ST-70 power supply, with the test designed to show relatively where that compromise stood as compared to others in the power supply section. When you consider the weakness it represents, the very high cost of good NOS or even good quality used GZ34s, and the poor quality modern replicas available -- all versus how well the SS/buck approach mentioned addresses all of these concerns, it becomes a very sensible compromise that is surely more appropriate and practical for today's audio environment. Still, I very much appreciate your pointing out the reality of where the rectifier tube compromise stands, versus the reality of normal use.
Dave
Chicago -- I did in fact test for low power THD levels, as they can actually rise in some designs from that of higher power output levels. I did not post them for not wanting to create information overload, but here they are at the same test frequencies at 1 watt/5 watt levels (again, presented as an average between the two channels):
@20 Hz = .055% / .11%
@ 1 kHz = .035% / .043%
@ 20 kHz = .115% / .50%
This is pretty darn good performance from any vacuum tube amplifier, let alone from a stock 55 year old unit build from a kit!
Dave
In the for what it's worth column -- I did a quick retest of my unit against the FTC ratings for the ST-70, as mentioned in post #23. On the low end, 50 Hz had no problem at all meeting the spec, with and average THD at 20 watts power in both channels coming in at .3%. Of course, at 1 kHz it was no problem either, with an average THD at .075%. As suspected, it is the 10 kHz distortion level that sets the upper limit of the power response band, with THD at this frequency coming in at .88% on average.
There would seem to be some wiggle room on the low end of the specification however, as my unit would produce .70% at 20 Hz under the FTC power conditions, which would also be in compliance. But other factors may have come into play from a manufacturing concern to cause the reduced power response band on the low end -- but that is purely speculation.
Dave
I’ve rotated my 90’s production ST70 Series 2 (produced by Sound Valves) back into my system. The circuit is mostly based on the original but uses a 6GH8A driver/inverter, has all SS power supply and a larger power transformer. I’ve never had an original ST70. The Series 2 performs very well though it certainly is not the end all in tube amps. The only mod I made was to exchange all the coupling caps with higher quality caps. I’ve been considering a tubes 4 hi fi build.
Dave,
That ad would be a great piece of Dynaco period lore/documentation to have. Where did that appear, if you can recall, approximate date?
Thanks
6
Is this it? 3 October 1975
6 -- It would have been absolutely no later than mid 1970, because I remember seeing it when I was still a teenager when my family lived up in Indianapolis. After I graduated from high school that year, my family immediately moved to Georgia.
As a teenager, I didn't have an ST-70, but had a buddy in high school who did. I still have a few of the hand drawn schematics I drew from that period of my life -- one of which is the ST-70, drawn on a piece of notebook paper, that I copied from his manual. That was probably in 1969. The page has a note written on it at a later date simply saying "New Rating", with the information I posted above, so it was almost certainly in the 1969-1970 period, give or take on the date of the publication. I clearly remember writing the note of the new ratings on the page as a result of reading that piece.
I do not remember the publication as being one of the first rate publications of the day (i.e. Popular Electronics, Audio, Stereo Review, etc.), but more of a lose leaf publication, like Rolling Stone -- but I'm hardly clear on that point.
One other hand drawn schematic I still have is a copy of the Dynaco MK III schematic, that I remember drawing in 6th grade during some free time!
Boy how time flies when you're having a blast!
Dave
Edit -- based on Pio's info, I wonder now if the piece I saw was a campaign piece against the up-comming regs? It was a long time ago!
Pio -- Nope, that's not it, but at least I got the new ratings correct. I am really beginning to think that the piece I saw was a pre reg campaign piece -- written by David Hafler. But thanks so much for finding that!!
Dave
Dave -
Great series of postings, very enjoyable.
I have always maintained that most folks have never heard a stock ST70 in good shape. Sure the "mods" sound better - take out a 45 year old board with leaky caps and out of tolerance resistors, charred phenolic PCB and wax dripping - put in a new mod board - wow, what an improvement.
I'm also humble enough to admit that I'm probably not 2% as clever as David Hafler was with tube circuits. It takes a bit of hubris to think that one is qualified to re-design the largest selling tube amp of all times and think you're going to make any significant improvement. Sure, there were some cost containment decisions, but the end result is pretty impressive.
FWIW I've had pretty good luck with the Sovtek GZ34's. Given the relative cost they're not a terrible option.
I still have a pair of ST70's in daily use here. One is an exact rebuild of a factory unit (re-etched PCB using original resistors, modern caps, new chassis, cloth leaded transformers, 7199's etc). The other uses the AVA Super 70i board.
Waiting for the next installment!
- Gary
6 -- In the SCA-35, much of the loss goes back to the very reason I developed the original EFB circuit in the first place: The cathode bias system in that amplifier allowed each channel individually to operate and measure pretty well, since the idling channel not only tended to act as a B+ regulator during testing of the active channel, but more importantly, caused the active channel to operate under pseudo fixed bias operating conditions. In keeping with the practice of the day then, it let single channel performance look pretty good.
But if you drove both channels together, the house of cards fell apart -- and the new ratings clear show that. In that condition, the the output stages operate with pure cathode bias, from a completely unregulated power source. The result is that power output drops, and distortion rises, both quite significantly. Note that the new power rating is just 40% of original single channel power. Even the highly de-rated ST-70 still approaches 60% of original rated power output under the new ratings. Adding EFB to the SCA-35 and ST-35 makes a serious dent in the performance that is lost when both channels are driven, reducing quiescent bias current and operating temps as well for extended component/tube life.
To the original point you made regarding design compromise versus the reality of use, the original bias system worked "well enough" in normal use -- but it was a serious compromise none the less. It did keep the price point in check however.
Dave
The Power Output Stage Pt. 1
The output stage of the ST-70 harkens back to Hafler's earliest days at Dynaco. His first output transformer -- the A-430, as used in the inaugural MK II amplifier -- was specifically designed for use with EL34 tubes. With a 4300 ohm primary, and screen taps placed at 33% of the primary winding, this load and screen tap position was experimentally determined to produce the greatest linearity from these tubes, coupled with a good degree of load regulation. The A-470 output transformer, as used in the ST-70, has the same exact specifications, at a somewhat lower power rating. Unlike the original A-430 transformer, the A-470 also includes a 4 ohm output tap as well -- this to accommodate the 4 ohm speakers (notably AR) that were starting to appear at the time.
So the ST-70 operates the output tubes with the same loading conditions as Hafler's original amplifier does, but operates them at a lower B+ level (~410 vdc vrs ~450 vdc) to achieve a lower power output level. Which brings us to the first myth about the ST-70's output stage: Lowering the quiescent current level (i.e, Biaset voltage) to extend tube life. From a standpoint of absolutes, lowering current levels will extend tube life. But in doing so in the ST-70, what is the practical return?
A common battle cry for this practice comes from those who categorically say something like: "Because tubes were so cheap back then, manufacturers ran the tubes right to the ragged edge for the performance ratings wars, and didn't care about tube life". No doubt in some cases that's true. But that line is said so often, that the statement has nearly become fact for all cases, regardless of what the individual facts actually are. So what about in the ST-70?
The 15.6 ohm cathode resistor causes the output stage to operate at 100 ma total cathode current in each channel, when the Biaset voltage is set for 1.56 volts as instructed. With a matched tube set, this is 50 ma per tube, with about 45 ma of it conducted by the plate. With 410 volts across the plate and cathode then, this equates to 18.45 watts, which as a percentage of the very conservative Design Center 25 watt plate dissipation rating for these tubes, equates to operating them at only 73.8% of their rated dissipation level. Even when operating the amplifier from a 122 volt line and still using the recommended Biaset level, the dissipation only climbs to 19.4 watts, for 77.6% of rated capability. These are both very conservative levels to operate these tubes at -- particularly when you consider it is being judged against the Design Center Rating value. The more common Design Maximum Rating System that was in place at the end of the tube production era rates the EL34 as a 30 watt tube, meaning the tubes would only be operating at 61.5% of capability (64.7% at high line voltage) under that rating system. With such conservative operation of tubes that are designed to conduct a continuous 165 ma each (Design Maximum rating) -- both from a dissipation and current flow standpoint -- backing the quiescent current level down by 10 ma per tube to save on tube life will gain you precious little of what you are trying to achieve, but it will give you a whole bunch more distortion!
If a THD test set is connected to the ST-70 and each channel is individually driven with a 1 kHz signal to 1 db below the rated power of 35 watts (about 27 watts), it will be found that the lowest distortion operation point is achieved with a quiescent Biaset setting of -- you guessed it -- 1.56 vdc, or veeery close to that setting. If you go below OR above this setting, distortion will climb, and do so rather rapidly.
For example, with a Biaset voltage of 1.40 vdc (45 ma total current flow per tube), 1 kHz THD climbs nearly 55%. If you reduce it further to 1.25 vdc (40 ma per tube) it climbs another 170%, for a total of 225%!
So, reducing the current draw of each tube by 6% of its rated cathode current, when it is already operating at just 30% of rated cathode current and 62% of rated plate dissipation, all to gain what, 225% more distortion? That is a very poor compromise to make, versus the very well thought out operating conditions that Hafler set up for the tubes to operate at.
But what about using different tubes? The 6L6 in many of its various forms, manufacturers, and sources, is a popular alternate for the ST-70. The pin out is the same, but requires slight alterations to the bias supply to bias the tubes at a reasonable value.
Assuming that appropriate bias supply changes were made then, using the popular 6N3C-E Russian derivatives will both reduce power, and increase distortion, due to the less than ideal loading conditions offered for these tubes. Maximum power drops to 24 watts RMS per channel at 1 kHz, with both channels driven, while THD rose to .5%. This represents a 36% loss of power, coupled with a 61% increase in distortion as compared to sockets stuffed with EL34s under the same conditions.
6L6 class tubes also had a minimum distortion operating point of around 50 ma per tube as well. But at this level, these tubes are operating at nearly 90% of rated plate dissipation capacity, and much more of rated cathode current capacity as well. Additionally, high power 20 kHz sine waveforms take on somewhat of a triangle waveform at this frequency, with THD running nearly 6% at 24 watts output -- and this at the optimum 50 ma current setting. At 40 ma, distortion at this frequency is nearly 10%.
There are all manner of accolades available in abundance about the sound produced from using 6L6 class tubes, and reduced quiescent current operation as well. I would never suggest what someone does or does not enjoy in their sonic quests, but I can say that given the performance intentions that Hafler established for the ST-70, using 6L6 class tubes, and/or reduced quiescent current levels in place the the designated tubes/setting, will cause it to fall far short of that mark.
The only pic to show is that of 20 kHz sine waves at the onset of clipping being squeezed into somewhat of a triangle formation at elevated power levels when using 6N3C-E tubes. Distortion of this waveform is ~5.5%. This is invariably due to the lower than optimum loading conditions being offered to 6L6 class tubes, which are very much happier when employing a 6600 ohm load, when operating in UL mode.
In part 2, alternate modes of operating the output stage will be examined.
Dave
Dave makes an important point here. The Dynaco output transformer A430 and the A470 have ultralinear screen taps at 33%. Many folks mistakenly think they are at about 40%.
Dave, is the A431 output transformer (4,8,16) ohms connections also a 33% UL tap transformer?
As many know, the biaset voltage of 1.56 vdc was chosen to match the voltage of a brand new out-of-the-box carbon-zinc battery cell. The end user would use his VOM (nowhere near the accuracy of today's meters) and note the reading of a new battery cell. Whatever his or her meter read (say 1.7vdc as an example) would be the base line for adjusting the bias. So when the bias was adjusted to the value of the example 1.7 vdc on their meter, the amp was actually adjusted to 1.56 vdc or 50 ma per tube.
Some rumors are out there stating to the effect that because you have to adjust to 1.56 vdc (to match the battery) then the bias is by definition too high. What Dave has just shown us, the best bias for the EL34 tubes is 50 ma per tube, Period. If Hafler had determined that, for example, 40 ma per tube was ideal, the biaset would still be 1.56 vdc. He simply would have chosen a different resistor to get the "reference standard" battery cell of 1.56 vdc. Every household had this "reference" voltage source in their kitchen drawer.
The 6CA7 should pull less screen current, how does that affect overall operation?
Sent from my SCH-I605 using Tapatalk
And, the A431S new production unit from Triode Electronics also employs 33% screen taps.
The FTC chart is really an eye opener. I had all the Dynaco tube amps and a Marantz 8B. I always thought the ST 400 was a huge performance improvement. I never looked back.
