JustMe2023
Member
Musical Power Supplies make it in the original size.
He's actually working on it right now.
Just came across this ad while searching for something else. Anyone ever heard of them?
https://reverb.com/item/65255813-pacific-transformer-dynaco-st35-output-transformer-2023
Yes, that's the idea. Which tubes did you use? I'm guessing one might be 6C4. What problems did you have? I would probably start a project like this with a pair of EF86 driving a 6SN7 (three tubes). There are many options once you move to a panel instead of a PCB.Some years ago I did as you suggest and mounted an aluminum plate with 4 sockets and hardwired my circuit. It was just an experiment which worked but not completely successful.
My buddy is sending me his old ST-70 board so I can take exact dimensions.
Jack
Does the ST-35 OPT follow this Hafler patent (attached), or is it different?
may still use this winding method though.
the "reverse" winding.
Correct, and that's how a transformer is wound.I'll take your word for it, but when I wind a fishing reel, I go back and forth from one end to the other with the line and never consider anything backwards. Must be an engineering notation/language thing.![]()
I agree.These transformer discussions with Hafler in the year 2000 are an interesting read, combined with his patents that I posted earlier.
The DynakitParts transformers can't be exact copies since they have 4 ohm taps instead of 16. I wonder if they perform any differently because of it. On both of my tube amps, I find the 4 ohm taps useless even though my speakers do present a 4 ohm load across a large portion of their range. I think I would have left the transformer alone with the 16 and 8 ohm taps but moved the NFB to the 8 ohm tap. YMMV
