Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Does anyone know where I can find a schematic for the the fisher 400, serial numbers 10000-20000? The one I'm looking for should show a 5.6K resistor in the bias supply. Thanks in advance for any help.
I have one as a pdf file. It does show the 5.6K resister. PM me your email address and I will gladly email you back the zip file of it. Please mention in the PM that you want the fisher 400 manual cause I've the memory of a dead elephant and I'm likely to forget that's what you need.
Amphead4: Use the one for 20001-29999. Mine is a 32K unit and the 20001-29999 manual works well for it.
The one on HIFIengine is the older one with the 5.6K. If you'rs is in the 30K range you should have an 820 or 1K in the BIAS supply.
I have the 20001-29999 manual on pdf if you need it. PM with your email.
bobbyonions: The one on Hifiengine should suffice for you.
