wyn palmer
Addicted Member
"Speaking" crudely. The emf generated by the cartridge coil is defined by Faraday's law of induction i.e. e=N*dPHI/dt- where e is the developed voltage, N is the number of turns, and PHI is the coupled flux.Negative. A changing magnetic field induces a current in a wire. Same thing by moving the wire through a static magnetic field. If that wire is open-circuited there is no place for that current to go, hence (conservation of energy or something like that) a back-EMF creates an equal but opposite current, cancelling out the induced current. This is how an output voltage is generated by a cartridge. Leave it open circuit. Drive a short circuit (transimpedance stage) and you get maximum current. Everywhere in between is a mix, for example, loading with Rload = Rsource you get half of peak voltage and half of peak current, and maximum power.
The "back emf/potential" developed across the cartridge's inductance is governed by the equation v=-LdI/dt, where L is the inductance value and I is the current flowing, which is essentially a conservation of momentum (not energy, per se) constraint. i.e. no flow of electrons or energy transfer through the inductors field occurs when the inductor is open, but once it is shorted to ground the instantaneous back potential (ignoring any field propagation effects) must be precisely equal and opposite to the GENERATED emf as a consequence of these laws and of the application of Kirchoff's circuit laws.
As time progresses current will start to flow at a rate governed by these laws/equations, i.e. when e is constant, I will initially increase at a rate proportional to e and inversely proportional to L but will decrease exponentially with time to reach a steady state value that is proportion to the "loss" resistance in the inductor and whatever residual resistance actually exists in the "short".
The issue in this "problem" is not whether these trivial relationships hold but whether the current in the coil can create a restoring force in opposition to the motion of the cartridge that is sufficient to disturb the dynamics (signal output, tracking) of the system.
There is a form of reciprocity at work here that is extremely difficult to quantify.
However, whatever effect exists it is most certainly maximized by the use of a virtual ground (current input) for the loading/input node into the phono preamp, and there are those that claim the obvious superiority of such a configuration.
