I suggest this one as it is the range where most manufactures recommended loading occurs but is big enough to be able to draw a conclusion from the normalized audio.1000R vs. 10R,
My phones are embedded in my listening chair.Oh, I have an excuse: I'm a lazybag.
I.e., after JP had notified me of this thread (or respectively after I had read his notification, to be more exact), I simply googled the generator data of the Kleos and did a quick calculation - with the result being an expected ca. 0.06 dB roll-off at the upper limit of my hearing, even if the Kleos was loaded down to 1 Ohm only. So practically no chance for me to hear any difference whatsoever - and hence no need to get up from the sofa for fetching a decent headphone.
Greetings from Munich!
Manfred / lini
That's why I only use audiophile fuses. The "blown" sound is much more dynamic.A blown fuse causes a dramatic sonic alteration.
Using a SUT was touched on in the parallel thread to this one on another site and the idea was discussed that there was some benefit to using a SUT. I use Wyn Palmer's MM and MC phono preamps and I did a little experiment with three setups using my Benz Micro LP-S loaded at 750ohms: 1) MC preamp loaded at 750ohms, 2) MM preamp with 75kohm load resistor and Peerless 1:10 SUT and 3) MM preamp with 1Mohm load resistor then 900ohms primary load on a 1:15 Hashimoto SUT.
I did not make digital recordings that could be level matched but listened generally over several days to lots of records in the same volume range. I preferred the two SUT options. Is this more the design of the SUT being highlighted versus a technical advantage of having a SUT in the chain of gear?
(...) Do you think this pattern of changes in volume with loading occurs with most MC carts?
Indeed it is. I've seen numerous plots of mc cartridge outputs with different loads and they're always as could be predicted. Unlike a moving magnet cartridge, the source impedance of a LOMC is almost pure resistance. The series inductance is just a few microHenries, ie practically nothing. That makes things very simple, with no resonant peak within the audio band to fine tune with resistance/capacitance loading.It's a pretty predictable matter of voltage division.
I like this!Indeed it is. I've seen numerous plots of mc cartridge outputs with different loads and they're always as could be predicted. Unlike a moving magnet cartridge, the source impedance of a LOMC is almost pure resistance. The series inductance is just a few microHenries, ie practically nothing. That makes things very simple, with no resonant peak within the audio band to fine tune with resistance/capacitance loading.
The 10X impedance ratio is an industry-standard for loading a source. Turntable to pre-amp. Pre-amp to amp.Followup questions: If loading is really just a matter of loudness, why do cartridge manufacturers specify either a minimum load or a load range for their cartridges? And why is the minimum load typically around 10X the cartridges internal impedance?
At 10X the source impedance the signal loss (dropped across the source impedance rather than the load) is just under 1dB. I presume 1dB is arbitrarily selected as an acceptable loss.Followup questions: If loading is really just a matter of loudness, why do cartridge manufacturers specify either a minimum load or a load range for their cartridges? And why is the minimum load typically around 10X the cartridges internal impedance?
That's what I gather --- with the least amount of noise issues.At 10X the source impedance the signal loss (dropped across the source impedance rather than the load) is just under 1dB. I presume 1dB is arbitrarily selected as an acceptable loss.
So minimizing signal loss is the lone reason to have adjustable cartridge loading? Given that most cartridges fall between 3ohm and 50ohm internal impedance then a range of cartridge loading between 30 and 500 ohms would seem sufficient. I suppose there could be a discussion of how granular those load options need to be given they just result in changes in loudness.
