EICO Model 666
mbskeam
Well-Known Member
EICO - Tube and Transistor Tester Model 666
is this model any good?
from what I read it sounds okay.
will it test 6DJ8's?
thanks.....
It's an excellent tester and uses circuitry similar to Hickok. The 667 can do more pin positions and has a transistor tester but is basically identical to the 666, Satan's Choice. Watch out for errors in the published charts, though they're not usually as serious as sometimes thought to be. I did some analysis and a write up as a spreadsheet, some of which might be nonsense until you've gotten some experience with the unit, but it's here.
I have an "evil" Eico 666 and yes it will do 6DJ8's. I have a .pdf of the supplemental settings I can send you if you like.
Mike
