Pio1980
AK Member
Not as long as Elio, afaik.I'd drive that.
How long have they beeen saying "available soon"?
Friend that preordered passed three years ago.
At least a couple of yrs. When I have time I will dig thru my old posts.I'd drive that.
The Aptera will have quick charging, and since it can go *much* farther per kWh than any other vehicle - as much as 10 miles per kWh - it will get more range in any given time than any other vehicle. The extremely low aerodynamic drag of the Aptera means that you only would have to do 1 quick charge in any reasonable day of driving. To drive more than 400 miles, and up to 600-700+ miles in one day is fairly infrequent. I have driven a ~250 mile range EV - the VW ID.4 - which has fairly quick charging, on several trips 450 to 675 miles in a day. These took 2-4 quick charges, and always were needed also to use the loo or have a meal - and the stops were almost always no longer than it takes to do the other necessary things.I would drive that. At least you can't get totally stranded. Yes, your journey can take a very long time, if you had to wait for it to charge, on its own every time- but as long as you park it where it can get to the sun, you should never have to worry about a "bricked" battery. And, as light as it is- if it gets stuck in a dark area, it probably wouldn't be too hard for a couple of people to push it out into the sun, so it could recharge.
Also, as light-weight and small as it is- with that battery size- I'm guessing it should charge up pretty rapidly. It doesn't need huge amounts of current for long periods of time, to fill up the battery...
Regards,
Gordon.
They have built the production tools - they are making the largest carbon fiber body piece of any production car. The first production intent "body in carbon" has been built.I'd drive that.
How long have they been saying "available soon"?
Be quite the thing for many, hope it sees production. Does it have air-conditioning?The Aptera will have quick charging, and since it can go *much* farther per kWh than any other vehicle - as much as 10 miles per kWh - it will get more range in any given time than any other vehicle. The extremely low aerodynamic drag of the Aptera means that you only would have to do 1 quick charge in any reasonable day of driving. To drive more than 400 miles, and up to 600-700+ miles in one day is fairly infrequent. I have driven a ~250 mile range EV - the VW ID.4 - which has fairly quick charging, on several trips 450 to 675 miles in a day. These took 2-4 quick charges, and always were needed also to use the loo or have a meal - and the stops were almost always no longer than it takes to do the other necessary things.
The ID.4 charges at up to ~180kW and can charge 5% to 80% in 38 minutes. Doing the math, this is as much as 290 miles worth of charging per hour.
The Aptera should have at least 60kW charging rate, so to charge the same 5% to 80% might take about 35 minutes. So that is about 500 miles of charging per hour.
To put this in perspective, a 450 mile trip had two charging stops - and took about 9 hours and 10 minutes. That's 550 minutes to travel 450 miles aka 49MPH average. Those two stops were virtually exactly as long as it took to eat food, and use the bathroom twice along the way. So, even if you have an ICE vehicle that can drive 450 miles at highway speeds (say 70MPH average), I would imagine that you would want to stop for needed breaks for at least 20-30 minutes - and you might have to eat while driving in order to be able to arrive at the end of the trip in less time.
The Aptera would be able to do this trip with just one charging stop, of about 30 minutes.
Yes, for sure, and it has a heater - and air bags, traction control, ABS, etc. etc. The stereo in the LE has a transmission line sub, even.Be quite the thing for many, hope it sees production. Does it have air-conditioning?
www.notebookcheck.net
No commercial large scale lithium battery recycling exists. It’s unstable and tends to be very hazardous. Lithium mining has significant environmental impact. EV’s will make much more sense when an order of magnitude breakthrough occurs in battery chemistry, but you have to start somewhere. Fortunately only about 5% of the global new vehicle production is EV. I say fortunately because 41% of the world’s electricity still comes from nasty dirty coal. Modern gas engines are probably cleaner. A significant global shift away from gas to EV may not be such a good thing unless the global infrastructure is modernized in step.
How we pay for highways and bridges does need to be addressed, certainly. But the gas tax hasn't gone up in decades, and our infrastructure *in general* needs more maintenance and improvements. That's a whole other conversation. We all need better infrastructure.
Your not correct on batteries - they will and have lasted much longer than 10 years. They do take more energy to make *as we make them now* i.e. from raw materials. BUT the break even point of the carbon footprint is less than 2 years. ICE vehicles have a total carbon footprint that it MUCH higher at 10 years/same mileage - and fossil fuels will only get WORSE over time, because we have to use more and more energy to get oil. Fossil fuels are getting dirtier and dirtier.
And - we can and are recycling batteries. This is much less energy use to get batteries from recycled battery materials, than it does from raw materials.
The electric grid is getting cleaner and cleaner - because we are using the cheapest way to generate electricity - wind and solar. With more grid storage - partly from the batteries in EVs - we can get to zero arbon electricity.
So does the Fed Gov.Individual states tax gasoline
The roads don't maintain themselves cost-free.I think you're missing an important piece to the financial aspect of gas vs. electric. There will be a mileage tax on EV's. Gas owners pay a gas tax and if EV owners don't use gas then the government loses tax revenue. We all know they aren't going to lose out on more tax money they need to waste so make sure you factor that into the equation.
Right - the federal tax on gasoline is about 18 cents / gallon.
I completely agree that we need to stop use of all consumer single use plastic - the fossil fuel companies are desperate to profit as much as they can - and their profits come at the terrible cost of so many parts of the environment that all life on the planet is totally dependent on.
Again - we can recycle all the batteries we have already made. Reusing these materials means that at some point we can stop mining/extracting materials to make them. We extract oil and methane gas - this is a total loss of energy *because* we *consume* that oil and gas. We mine for almost EVERYTHING that we don't grow.
ALL manufactured products need to be fully recycled - after it is repaired and reused as many times and as long as possible. Throwing things "away" is a MASSIVE problem. There IS NO SUCH THING AS "AWAY". Planned obsolescence and designing for the dump - are all very damaging. Concrete and steel and aluminum are all FAR bigger mining and energy uses than batteries.
