That's why I used to use a combination of the two.Yes, that's true.
But depending on the location, I find that Elena's silimc is a bit slow.
PS also. I used to do a 80/20 combo in Marantz Player power supplies and Polymer caps in digital section, like Oscons, with Silmic in the output.In the signal path
I'll take your word for it, not sure if I have been in that situation, i mainly modded Players and Valve amps.In a signal path, if the voltage is low—less than 5 volts or down to zero millivolts—bipolar components are the best choice; the "Audio Note" and "Nichicon ES" series are excellent options.
In general, modern aluminum electrolytics are physically smaller than similarly rated caps from decades ago. Finding a cap with the same can diameter will usually require increasing ratings, whether it's working voltage, capacitance, operating temperature range, lifespan, or all of the above. Since the big power supply filter caps are often mounted using clamps, this can be challenging to find something that physically isn't too small.
First: It is always safe to increase the working voltage rating on power supply filter caps. In your case (originally 50V working voltage) you should not hesitate to go up to 63V, 80V or even 100V if it helps you find a cap with the correct diameter to fit the original clamps without modifications.
Second: Increasing the capacitance of power supply filter caps by 25% to 50% is a no-brainer. And you can safely increase by even more, but you are chasing diminishing returns. Increasing the capacitance will improve the smoothing of the unregulated DC voltage (decreases the ripple voltage), and will also help you with finding a cap with the correct diameter to fit the original clamps. Yes, do note that there is an increase in the inrush current at power up, but this will not overtax the rectifiers or the power transformer since it is only a transient event. If you want to read more about this, refer to the estimable Rod Elliot (I have no affiliation). He has an excellent "no-BS" article on his website regarding power supply design and addresses the myths around increasing power supply filter capacitance. If you are interested, look at section 5.3 here: Linear Power Supply Design - 5.3 Major Myth Regarding Capacitance
Good luck. Cheers! -Steve
Have used Hifi Collective for the last two decades.
hifi collectiv They have limited stock; their shipping rates are good, but delivery is slow.
Digi-Key also has stock, but the shipping costs are high.
@KeithTr, I also have a L10 and have been looking for a replacement filter cap. Have you pulled the 6800uF caps to see if they are screw or solder terminals? I can find United Chemicon caps with the correct dimensions but with screw terminals and stud mount, not clamp or none.I am working on a Luxman L-10 and contemplating increasing the two filter capsper channel from 6800/50v to 8200 63v. Even then, caps will be smaller than the old 6800/50v and require some sort of adapter.
I wanna know who told you this...If the voltage present in the Signal path—as well as the actual operating voltage—is, for example, 5 volts, while the capacitor is rated for 50 volts, it becomes difficult for the insulating layer to form.
Try it and you will see the differenceIn the signal pathI wanna know who told you this...
I am not an engineer or a designer like you, but I have experimented extensively with several devices, and there is a noticeable difference.I wanna know who told you this...
There is an interesting caution at the Hans Hilberink site for this L10, it seems the big caps will not discharge at power off, so before poking around in the amp be sure to discharge them properly otherwise one could accidentally cause damage.
