Using an audio technica VM 760 SLC. Hard to believe adding weight, like in the day you'd put a nickel on the headshell if your record skipped.Add weights to the headshell.
What cartridge are you using?
no, no, NOLooks like I can remove the weight and machine it down.
No, that's not true for the 598The tonearm was designed back in the days when cartridges weighed more.
You have many years of repairing turntables but you suggest machining down the counterweight before evaluating the tonearm?So either machine down or replace counter weight or add weight to the head shell.
I have a box of left over head shell weights from many years of repairing turntables.
It's a dynamically balanced tonearm, it may need to be repaired, just don't take it to a machine shop....The odd thing about this unit is I've tried the cartridge that the previous owner used? Same problem.
Great advice. I'm going to order some weights. Thanks for your help.no, no, NO
yes it doesThat big knob on the side of the arm gimbal doesn't control a VTF spring by any chance, does it?
that's a possible solution but I suspect there is something the OP is doing wrongAdd weights to the headshell.
the photo looks like a Pickering XV15 which weighs 6 grams, the same weight as the Shure cartridge that I use in my 598What cartridge are you using?
It shouldn't need extra weight at the headshell.Great advice. I'm going to order some weights.
I'll call around. ThanksIt's a dynamically balanced tonearm, it may need to be repaired, just don't take it to a machine shop....![]()
The wires don't appear to be tight. The wires are directly under the pivot point, which shouldn't cause tension?So for comparison, I have a Grado Black on mine which weighs 5.5 grams.
The counterweight is about 3/8” away from the tone arm base.
Have you checked the tone arm wiring beneath the table to see if it is too tight, pulling the tone arm up?
To be honest, I don’t remember.Great advice. I'm going to order some weights. Thanks for your help.
Thank you for the great advice. The tunearm looks brand new. No loose or bent parts, so hopefully it's just user error.To be honest, I don’t remember.
Your cartridge weighs 8 grams, my Grado weighs 5.5 grams and is perfectly fine.
That rules out the need for additional headshell weight.
Please don’t not throw parts, tone arm repair or machining at this before analyzing the problem.
Could be something minor.
There is a very lengthy thread on AK on the 598.
Might be worth a read.
Sorry, don’t have the link.
