Empire tonearm not in balance
Is it possible that there was more than one rear counterweight available for these turntables and you have a very heavy one and others have lighter ones? This is a very interesting issue.
Is the arm floating in this picture?
Or is the (CUE lever) preventing it from lowering any further?
There is an adjustment for that.
Check the action of the CUE lever make sure there is plenty of space for the tonearm to descend completely to the LP surface.
I checked the manual but it does not show any CUE lever adjustments.
It might appear that we may have incorrectly assumed that the counter weight was in-properly adjusted.
Buck
Buck
But he said with the counterweight off, the stylus sits firmly on the record.
Just maybe the VTF dial is way off due to a stretched spring or something, check the weight with a scale.
Or, balance the tonearm with VTF at 0, then add two grams of weight to the headshell (temporary with bluetack or tape) and see if the arm goes to proper position.
Buck
The fix was to remove this set screw, oil the bearings and tweak the tension. 55 years can have its toll on delicate tonearms. Thanks for your help. I learned about this turntable, thanks to you
Buck
Looks like the cue arm plate is bent! Should that screw in the photo have a head on it? Should I use a needle nose pliers to straighten the cueing plate?
