It does move in all directions. Cueing works too,When you gently push it down by the headshell is there any resistance or does it move freely up/down/left/right?
I set the VFT dial to 2 grams but the headshell is no where near the record. Even if I set the tonearm post very low.Just to be clear, did you balance the tonearm with the VTF force (knob on side of arm) set to Zero? Then did you dial in the
desired weight with the VTF knob on the side of the tonearm?
It almost sounds like you are trying to balance and adjust the VTF weight with just the counterweight like a static balance arm which this is not.
what happens when you remove the counter-weight?I set the VFT dial to 2 grams but the headshell is no where near the record.
The tonearm should be parallel to the record surface when the stylus is in the groove.Even if I set the tonearm post very low.
When the counterweight is off the stylus goes down hard to the record surface. Photo is parallel arm, no counterweight.what happens when you remove the counter-weight?
I don't believe so. It travels negative of 0 just a fraction of an inch. Travels past the 4 mark by just a fraction of an inchIs there any chance the VTF knob has turned beyond its normal limit? Like it is 360-degrees off somehow?
Mine is as close to the pivot point as it can go?I'm using a Shure V15 II which weighs about the same as the cartridge you have.
With tracking force set to zero and tonearm floating horizontally (balanced), this is how much latitude I have with the counterweight...
And the cartridge is a good inch above the recordMine is as close to the pivot point as it can go?
It feels like the cueing platform is restricting the tonearm from being where it should be. The person I purchased this turntable from said his dad played it a lot. So this is very puzzling.And the cartridge is a good inch above the record
if that were the case, it would not have lowered to the record surface when you removed the counterweightIt feels like the cueing platform is restricting the tonearm from being where it should be.
Mine is similarjust for context, first photo is in the forward most position, second photo is balanced
Balanced
No hash, but it looks like more is in mine. How's that for bragging rightsHere's something I just discovered, the counterweight has a removable plug. Maybe someone added some weight inside of yours? It's from the 1970's so maybe a gram of hash
never hurts to lookNo hash
The plug isn't heavy enoughnever hurts to look
will it balance without the plug in place?
