Wait a minute. There were at least four different EPI tweeters. Would you please clarify what you meant by the "advancement" of the tweeter?
The inverted dome, masonite top plate, with the big magnet.
Not sure what you mean by 'four different tweeters'. There were different versions of the only tweeter used in the original line.......the original was altered buy changing the lead entrance from both leads coming into the voice coil next to each other to the leads entering at 180 degrees opposite each other.....the cone material was changed from paper to a phenolic...the magnet size was decreased. These were all variants of the original one inch, concave tweeter.
If you are referring to tweeters used after about 1980 or so, those I don't know or care too much about as they were, at that point, just another mediocre speaker company on their way out of business.
That makes more sense.
I guess there are still a lot of people that like their speakers from a "mediocre speaker company", including me.
......and that's all that matters, isn't it?
Yes, except now I want to know what I have been missing.![]()
There's a simple way to find out.
Just make sure you have some power on tap. I saw a post the other day where someone was going to use a 16 watt per channel receiver to drive a pair of EPI 100s. Well, they will make noise......![]()
I have written this before but will bore you all with it again.
The EPI 100 was a relatively inexpensive speaker. It is not surprising to see them linked, more often than not, to a lower powered receiver. Due to the forces of marketing among other reasons, I would think if people had more money they would buy a higher powered receiver as well as more expensive speakers.
What is your opinion of the cast aluminum Epicure tweeters? Also inferior to the Masonite ones?
Agree, I particularly like the "gold ring" tweeters with the smaller magnet and the plastic face plate better than the original masonite, but that's one guy's opinion.
Oh... that one.
Thanks!
