You are reading the old part of the thread.My question is how do you want to use the EQ?
Same as in a loop - from signal out.
I think you are missing my point. You are not feeding the eq from the amp out but you plug the source to the eq instead of having it plugged to the amp.Sorry, it doesn't work that way.
That's why I asked if the dac is his only source. If not, he can add a selector on the eq input which is much simpler and cheaper option than to look for a new amp, especially since he likes his current amp a lot.That means if you want to use "whatever" you are restricted to one source.
Plug all sources in a switch box then the box to the eq or amp. Example: http://www.mfspdesigns.com/index.php/en/all-products/switch-box/switch-box-rca-4in-1out-detailI'm also really interested in the 'selector switch option' but would need guiding for that one!
Yes it is.Is that right?
Ok I get that! Thanks. Looks straightforward. But just to confirm:
I can feed my DAC source into the EQ before the Amp, and plug the EQ into any Amp line in now, and the future provision of a switch box into the EQ would enable me to do the same but have other sources, such as CD, without having a tape monitor function on the Amp.
Is that right?
Does this routing have any detrimental effects on signal processing/noise etc? (Assuming the EQ is working OK.)
What kind of crackle? If it sounds digital could be the dac glitching, if not - could be the EQ pots. Can't tell without a listen.If you've any thoughts on intermittent crackle it would be appreciated.
