My bench has been swamped with power amps and I need a few more things to bench test them.
I have:
signal generator
tektronix 2215A scope 60MHz
2 8ohm dummy loads from digikey: FVE300-8.0-ND
fluke 115 RMS meter
I still need a proper set of scope probes. They need to have the 10x switch.
I'm looking at ones on digikey, but am not quite sure what I need, any suggestions?
I am going to get another pair of dummy loads.
Is there anything else I need?
Sure, a nice Audio Precision System Two or an HP Dynamic Signal Analyzer would be a really fun way to drop ten or twenty grand. But, those are luxuries. If you are serious about testing power amps, there is somewhat more modest equipment that I would consider critical. One can do very basic tests and troubleshooting with pretty much what you have now. However, if you want to properly understand circuit function, or do circuit development and optimization, or research new devices and topologies, etc etc, I believe a step up in capability is needed. In no particular order:
- An audio band voltmeter. Your Fluke only measures out to about 1 KHz. MUST HAVE.
- A burst generator to create non-continuous waveforms or, better, an arbitrary waveform generator. My first choice would be a stand-alone unit, but it can be done via a computer. It is also fairly easy to build a box that will attach to the output of your signal generator and create bursts, but this method is limited in flexibilty. MUST HAVE.
- A tunable audio filter, so that noise and distortion can be tested according to various standard standards. For example, it is pointless to measure amplifier noise without a defined signal bandwidth. This filter can be purchased or, if you are good at it, you can design and build one yourself. MUST HAVE.
- A thermocouple probe. MUST HAVE.
- A digital storage scope is very helpful for understanding clipping behavior and transient instabilities, and it lets you document and share your work. IMPORTANT.
- A reactive dummy load. Purely resistive loads are, of course, a requirement, but it is also very valuable to have at least one load that simulates a speaker. This is easy to build yourself. IMPORTANT.
- No bench is complete without an LCR meter with a choice of test frequencies. (At least 120Hz and 1KHz.) IMPORTANT.
I'd be happy to answer any questions on the above, discuss affordable strategies, alternatives, etc.
-k
