AvFan
So within a certain range of mass --- is lower effective mass better?
Thanks!
I think of effective mass in terms of resonance between the cart and tonearm so a lower EM isn't always better. But what @adnick is describing would lower the moment of inertia of the tonearm which is a good thing in particular if the record has an off-center spindle hole. In that case the counterweight is swinging back and forth causing all kinds of forces on the stylus as it navigates the groove moving side to side. I bet the spindle holes of most records are at least a little off center as well as when the hole is slightly larger than the spindle.
