UPDATE:
The Dynamat is sticking now. THe staple gun just helped the edges from curling since the material has been stored in a box for 10+ years.
Well, I got pretty much all of the assembly done. Wired them all up, filled the boxes with fiberfill, and closed em down.
The left speaker is working amazingly well. I haven't had a chance to really wind it up yet, but so far so good. I even wired the tweeter pot correctly! Go me!
However, there is a problem, the right midrange dome is not working. I could hear something missing, de-soldered it, checked the driver and no reading on the ohmmeter.
So, I disassembled it and sure enough, the voice coil has detached from the dome and one of the wire tinsels has broken on the *inside* of the dome. (usually it's from the outside).
Thankfully, I already have experience repairing mid range dome tinsels from my Quantum 5 project. I unwound one turn of the tinsel around the VC and checked for continuity and resistance. Reads 3.6 ohm, which is spot on. SO, the VC is good. It just needs to be reassembled. Wish me luck!
Crossovers wired and ready:
Assembly Process
Once I finish the mid, all that's left is to wire-tie the wires, attach some 8" table legs to the base, and add the felt padding around the edge of the rear cage.
What a trip!
