The domed tweeter works fine, but the super tweeter in both speakers don't work with crossovers. if I hook them up direct they do.
where did you buy the inductors?
I bet they are working fine. When they are plugged in outside the crossover you are hearing the entire frequency range. When they are in the circuit you are only hearing about 14kHz and above. Chances are your hearing above 14kHz falls off quickly. That's the same for most people. It's very hard to isolate the super tweeters when they are in the circuit.
Get an empty paper towel roll and play a signal sweep. You can put the paper towel roll up against the driver and your ear. This will help isolate the sound. Get a signal sweep off YouTube.
I got the inductors from Parts Express. Note, the AWG of my new inductors is thicker than the originals. The DCR is lower. This will change the crossover frequencies somewhat, but I don't care. They are close enough and they sound fantastic. But to the purist, you will want the right thickness for the inductors. The only way is to wind them yourself.
