Nice Milling Job!
As long as you have access, you might want to replace your input RCA plugs. Back then, they were located closer to each other. Now, modern RCA plugs are too fat to comfortably fit next to each other in those jacks. I had modern spaced jacks that I used on my amp when I rebuilt it.
I also noticed that your amp uses four ceramic .047uf coupling caps. Change C5 and C8 to 600v Paper in Oil types (like Westcap) and C6 and C9 to 400v (minimum voltage) MKP's (like Solen) and your amp will sound better.
I tried all PIO's originally and thought the sound was too dull, all MKP's and it was too strident, but when I mixed them it was more balanced. Don't go crazy on those caps, your limiting factor will be space. Russian caps probably won't fit only because the leads are so thick.
You're doing excellent work and I like your work.
