Tom,
Great looking frame, nice joinery. But you closed off some of the ventilation holes and that amp will get hot, especially now that it is dissipating additional power that would have been used by the disconnected tuner.
Make sure the amp sits well off the ground on tall feet with a well ventilated bottom cover.
For the poor man's variac-you're supposed to start with a low watt bulb (in series) and gradually increase the bulb wattage. I couldn't tell you where to stop because I use a variac. If you can't find a 200 w incandescent bulb, you can always wire two 100 w bulbs in series.
Rich
Rich
