A moderator I conferred with about this sad story reminded me of something that I want to mention to everyone who ships a Fisher tuner or receiver:
Remove the tuning flywheel weight before shipping one of these. I believe it's held on with a set screw or allen screw. Removing the weight won't affect the dial string and if the thing takes a jolt, the tuning arm shaft or the support bracket won't get bent.
The guy that did the packing should be Keelhauled from a CVN (Carrier) in shark infested water @ 30knots. Bet he doesn't survive in one piece either!! That is just GROSS NEGLIGENCE!!!
the only real way to pack these is in solid foam planks and bubble wrap, inside of double boxes. I've used expand a foam into gallon sized zip sealed baggies for the corners, let it expand and settle some before they harden, then put them in trash bags, and mush the unit into the bags at 4 corners bottom and top. Then pack with foam planks (cutting holes for the knobs to relieve stress) in double boxes.
remember my 400's bracket? got pushed back about a 1/4". I think you said you were gonna see about fabricating a transport block to alleviate such actions for future units.
Larry
