Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
I have a 500c in storage, if you continue having hard time finding what you need I can break out and shoot some close up pictures and post. Might be awhile though..
The power transformer is a voltage doubler, with about 170VAC output. Assuming that it has to supply a DC current of about 150 mA, it would have an AC current rating of about 500 mA. The heater winding(s) can supply about 8A total. the output transformers are about 6K center-tapped to 4 / 8 / 16 Ohms. An ohmmeter can ID the windings - colors are usually per the RMA standard: http://www.nostalgiaair.org/References/rmacodes/pwrxfrmr.htm http://www.nostalgiaair.org/References/rmacodes/audxfrmr.htm
The speaker taps will be a bit more difficult ('cuz' I'm not flipping MY Fisher over just now...) but you can measure it as described in the article: http://www.radioremembered.org/outimp.htm
If you have a voltmeter and a low voltage AC source you can pretty much figure it out. It's been a while since I've seen one...used a set off Ebay a few years ago for a project for a friend...
IIRC correctly for the power tranny:
black leads are 120v power.
red and red/yellow- Secondary power
blue and brown- to full wave bias rectifier
remaining leads are 6v filament power. There is one really short fat gray lead - filament power for the outputs (use your VTVM to find its mate). The other leads (green or yellow IIRC) fed 6v power to the FM section tubes.
The outputs.....from memory...
red-power in
blue and blue/yellow- to plates
black- ground
brown- 4 ohm
green 8 ohm
yellow 16 ohm
Good luck- MAK
