Omega -- I'm a bit lost here on a couple of things:
1. Back in post #55, you state that you change out R115 as a 10K resistor for a new 15K resistor. First of all, R115 was originally a 100K resistor (not a 10K), and secondly, why the change? Going from 100K to 15K for R115 will surely reduce the B+ to the phono preamps to an unworkable level.
2. Exactly how many "cans" are you working here with? In post #57, you state that C91D will be replaced "with a completely new cap 560 uF can". You also state that there is a new 100/100 can as well.
I'm hardly trying to play "gotcha" here, but simply trying to get a handle on exactly what is in this kit you are using, and what you're trying to do. Therefore, am I correct in assuming that the new dual 100/100 caps are in fact in a can that will occupy where the old C91 was? And, that the new 560 uF (C91D) is not in a top-of-chassis-mount can form, but rather, is a discrete axial device that will be installed somewhere under the chassis? That would make the most sense.
Regarding the connections of the C91 caps then, obviously (if I am correct), C91D will need to be installed somewhere that will accommodate it physically, as well as electrically. As for C91 sections A, B, and C, it will be easiest to convert the old design to the new one in the following fashion:
1. Back up in the first pic of your post #55, all three resistors, R121, R124, and R129 are visible. These are the green resistors, with R129 being by itself in the right side of the pic. Replace R129 with one of the new 470 ohm resistors.
2. Over at the actual C91 location (and again, if my assumption is correct regarding cap configuration), the purple wire will connect to one of the 100 uF terminals. The two red wires will connect to the other 100 uF terminal. The other new 470 ohm resistor will then connect between the two 100 uF terminals.
Finally, were this my unit, and if my assumptions are correct so far, then the single point terminal strip located next to the C91 location is no longer needed. I would first remove the old (now) unused wiring from it, and then take the black wire that originally connected to the C91D terminal, and connect it to the T-strip. This will then give a convenient point to connect the + lead of the new discrete 560 uF cap that is replacing C91D.
Of course, my assumptions could all be wrong here as well, so I hope I haven't added any confusion to the process. As always however, the devil is ALWAYS in the details, which is why I ALWAYS question them!
Dave
