Fisher 800c project for 2014
Power supply complete
Here are the final changes for the McShane Kit for the power supply
See how I had to accomodate C91D where C95 was.
I ran the NEG from the new C91D back to the original C91D NEG
attachment.php
Closeup
attachment.php
That completes the changes for the power supply
Next are the screen stoppers and cathode resistors
Cathode resistors
New 10 Ohm Cathode resistors on PIN 5 of each output tube
Before
attachment.php
After
attachment.php
What do I do with the 274 Ohm .5 resistors that are labeled screen stoppers on the McShane parts list?
Were the 10 Ohm 1/2 - 1 watt resistors labeled Cathode resistors on the McShane parts list the correct ones to put on pin 5?
Getting back to post 80: You're using a 3 tab strip. Is either of the outer tabs that you are using touching chassis??
No the center tab with screw is touching chassis but the outer two are not
In the end I only used a single tab on it. The POS wired directly
Thanks
Look at this pic from Dave's 800C rebuild - run the resistors from pin 4 to pin 1, snip the bridging wire that connects pin 4 & 8 between each socket, then add a connecting wire to pin 1 on each socket. The big 1.2K resistors need to connect to pin 1 on one of the sockets.
attachment.php
Yes, they run from pin 5 to ground. Make sure you move that 220 ohm resistor to its own ground too.
edit: sorry, you've already installed 10 ohm cathode resistors above.
Don; Looking good so far. (going faster than you thought it would, ain't it?)
Going back to C98. You could also connect the NEGATIVE side(along with the rest of the stuff) to the outer terminal (unused). It would get everything off the cap and actually give you a better connection circuit wise as only 1 wire/lead/etc is connected to the cap itself.
Well, The red wire to POS was a little short to reach the outer tab and I didn't want to (lazy) run a new one so I did not use the outer tab. It reaches the C98 POS can lug fine. This was my last connection of the long day
I justified this by noting that the original C98 POS had two wires running directly to the can cap lug.
If you think that it should be rewired I'll do it
I dunno, its been 10 months. But I would surely be wallowing in despair and frantically exchanging phone calls and emails if it weren't for the GREAT folk at AUDIOKARMA
Bruce; I don't recall the 220ohm resistor that you're talking about on the 800-C. I just looked at both of mine. NADA, as I reconnect it right on the riveted socket mount for those units that have it(ie: 400's). Here's a picture of BugleGirls 800-C underneath before any work done to it. No 220ohm from pin 6 on any tube. So it looks to me that it's a 400 only item.
Don; On the 400 there is a 220ohm resistor between pins 6 on one end and pin 3 on other end V16 or 17(depending on early(<48001) or late version(>48001) as a grounding point. With the addition of the 10ohm cathode resistor, the 220ohm loses it's ground, so must be moved. The closest ground would be the tube socket mounting ring. Pin6 on the 7868 corresponds to pin6 on the 7591 and pin 3 on 7868 is pin 5 on 7591. There is no corresponding part from pin 6 to pin 5 on the 800-C chassis as shown here.
attachment.php
So just changing the pin 5 ground jumper to 10 Ohm resistors is all that is needed?
No additional assembly required for the Cathode resistor upgrade on the 800c?
Installing the Screen Stopper modification
Here is how I did the Screen Stopper modification
Added a 270 Ohm resisitor between Pin 4 and Pin 1 for each output socket
Cut the jumper between Pin 8 (Of one socket) and Pin 4 (of the next socket)
Add a wire jumpering PIN 1 on all sockets
Move the Orange lead from Pin 8 to Pin 1
Move the 1.2k Ohm resisitor from Pin 4 to Pin 1
Before
attachment.php
After
attachment.php
Marked up
attachment.php
C116 and C117
Another difference in my early serial # unit
I am down to the final components to change and I cannot find C116 or C117 on the schematic or on the board
They are just not there
attachment.php
Other images in post #95 show greater detail
I am guessing that I should just leave those parts out?
Any advice?
C116 and 117 are on the P.I. tube(s) on the later "Standalone" units. The Early executives didn't have it due to changes in the output section and P.I. circuits. There were a few things that threw me too when I redid mine. They aren't needed in the 63 Executive.
63 Executive
attachment.php
Standalone 800-C
attachment.php
Thanks Larry, just less work I have to do
This is only the second difference I have noted, the first being the three 180 resistors
Whats left? The last four items on the parts list:
four 200k resistors to replace four 330k resistors R21,R22,R23,R24
four .1 uf PIO caps to replace four .047 caps C16,C17,C18,C19
two 10 pf caps C14,C15
Then a complete review of my work, checking solder joints, cap polarization, connections and wire runs
Make sure the fire extinguisher is charged
Then begin the process of powering up and measuring voltages
Then its Oh-Beer-Thirty
C99 C101 C105 C106 replacement
Here are the changes for V18
attachment.php
Here are the changes for V19
attachment.php
