Fisher TA-600 vs. 400 - which to restore?
In your case ALL 6. I marked them with their part #'s. They may be backwards as far as channels go but it's right as far as which goes to the output's and comes off the P.I./driver tube.
They are all .1uf 600v so you can use almost anything in that value and voltage. You can go up in voltage to 630 also.
attachment.php
You see the SALMON colored electrolytic below the third coupling cap on each channel? They are 25uf 6v. REPLACE them with 27uf at 16v or 25v. 647-UPW1C270MDD (Radial) 16v. or 647-UPW1E270MDD (radial) 25V.
They are all .1uf 600v so you can use almost anything.
Thanks for your help! I really appreciate it.
