hotrodman21
Definitely a fantastic table, one of the better ones for its time!
So, let's roll through the equipment.
I'm rolling a 2M Red on the table currently, running to a brand new Ortofon headshell. (The original headshell's solder failed just the other day.) This pipes through brand new RCA cable leads put on by Gibson's. These plug into a TCC-750LC, as suggested by you folks.
This is where things get interesting, I have an RCA switchbox coming off of the preamp which can be switched to my receiver, which pumps out to multiple rooms at the flick of the channel switch, one switch that leads straight into my 16-Channel mixer, to record any signal coming off of it to my PC. (An ElectroVoice BK-1642 for those curious) Then, one more switch that leads into my headphone amp next to my listening room sofa. This runs into Marshall Monitor headphones, which runs to Me, in a Snuggie. But, that's beside the point. The receiver end, runs into a new Sony amp. Nothing special really, I need to track down a decent vintage one, and for Pioneer heritage reasons, the SX series looks pretty cool. Depending on which switch I run, it could also run out to the living room surround. Which I hand picked, with Edifier speakers, a Pioneer 4k receiver (For the TV surround) A hand built center speaker, made from plywood, and Pioneer Car speakers I found at a garage sale. (Sounds much better than you would think) A brand new Polk Powered Sub, and, I swap the wires between the Rear Surround, and the Sony receiver, as the speakers run a double duty depending on where I'm listening.
If that all makes sense. Let's move on.
The way it's aligned! I bought a digital scale, and the cartridge is running at exactly 2.8 Grams on the scale.I bought an alignment scale on Amazon, unfortunately, I couldn't tell you what system it's using... It appears aligned, but I don't know which scale to use from the fourms.
A point was brought up that I forgot completely. Anti-Skate.
So, my anti-skate worked about six months ago. Then, I believed it was wrong. So I messed with the little guy. It broke. This is when I had the entire auto-return mechanism restored. 200 dollars later, and she's home. Working anti-skate, but I am unable to turn it without breaking it, according to the technician so it has gone "un-messed-with" since, around February.
I believe one of the wires may be providing resistance within the deck, providing tension against the tonearm as it goes across the LP.
I know for sure the albums aren't damaged, as it does it with the brand new albums I purchased a week ago. (Bob Seger, Ride Out) Wrapped in shrink, new from Amazon.
As for the stylus being dirty, if there is any visable fuzz, or dust I gently blow it off before play. However, I don't believe this is a great method, I keep meaning to pick up a brush for it.
Hope all of this helps thanks for the fantastic responses everyone!
Edit: I knew the a-s broke, as the stylus refused to play anything else than the run-on of an album, then it would skip back onto it immediatly.
