Waiting......and Odds and Ends
After the recap, the tuner was put back into service, with a few details noted to take care of:
1. The additional B+ dropping resistor took care of the vast majority of over voltage produced by the silicon rectifier, but it was noted that both the B+ and heater voltages were still on the high side with a 121 vac line, with the heaters being nearly 10% so. The addition of a CL-90 brought the heaters to within +4% of target, and the B+ within +4 vdc of target. This is particularly important for tuners, as one of the all-to-typical problems that develops within the tube types that are used in tuners is heater/cathode leakage or shorts. That conditions will often disqualify a tube before poor Gm performance does -- and high heater voltage only serves to accentuate the possibility that leakage will occur. Keeping the heater voltage within 5% of target will help ensure maximum life from tuner tubes.
2. Some techs don't realize what fanatics we Fisher fans are! This unit had the typical 8 volt Fuse Style bulbs SOLDERED in place for the dial lamps, because someone along the way apparently used the fatter festoon lamps in this unit than were called for, which broke out (or required the breaking out of) the dial glass side of the lamp well to accommodate them. This ruined the four sockets, and meant that the proper festoon lamp, or even the Fuse Style lamps would no longer snap and hold in place, requiring the previous tech to solder in the existing fuse bulbs. It works, but is hardly convenient when change out time comes.
Different options were examined to try and fix the broken out sides of the socket wells to have them work as Fisher intended them to, but all were involved, and hardly left a stock look to the fix. At that point I realized that by disconnecting and removing the clip from each well, and simply reversing them -- so that they clamped the bulb between the clip and the remaining in tact side the lamp well, a fix could be had with no one really the wiser about it. It worked perfectly!
3. This unit also suffered from a Muting indicator lamp that was well, flaky. Turn on the Muting function, and maybe the light would come on, maybe it wouldn't, but usually it would wink at you -- although you were never really sure just what it was going to do.
That was traced to the switch on the control, and while a replacement has been found, it still has yet to be delivered. And so we wait........
In the mean time however, the rest of the tubes came in, so with hot tubes in all sockets, the alignment could be checked even with the Muting control removed from the unit. I use a Sound Technology 1000A for the tuner circuits, but still prefer to use The Fisher 300 Multiplex Generator for the MPX work, not only for sentimental reasons, but because it is a superb piece of equipment in its own right as well. For the tuner circuits however, the 1000A is unsurpassed in the quality of alignment it can provide for, and the time involved to achieve that end.
Once touched up, this particular unit achieved 20 db of quieting with a signal level of just 1.25 uV which is quite remarkable. For those with owner's manuals for the 200B, you might note that the spec for 20 db of quieting is a signal level of just 1 uV........
We are all very familiar with the power rating wars, and in how the manufacturers all got caught up in trying to spec that the unit they offered had more power than a competing unit -- when in fact it may have had less! Even Fisher was caught up in this to some degree -- but only slightly compared to the degree that some manufacturers were. Well guess what? The same game went on in the tuner business as well with sensitivity figures.
Most quality tuners of the day will have a specified sensitivity rating (for 20 db of quieting) under 2 uV, but only the best ones will achieve that performance level. In my experience, the better Fisher tuners will always be under a 2 uV level, and often around the 1.5-1.6 uV range. So for this bad boy to clock 1.25 uV is something special indeed. By comparison, when the original tubes were reinstalled, 20 db of quieting required nearly 3 uV -- due primarily to a weak Nuvistor mixer tube, but also to an IF strip that needed touching up.
Once the Muting Control switch arrives, this project will be a quick wrap up, since everything else ready to go. Like the X-202B amplifier, the FM-200B is Fisher's best and most practical tuner, that will really make the best modern tuners have to work for their supper!
Pics include:
1. Just one solder connection left to go. After installation, the CL-90 brought all the voltages nicely within range now. The T-Strip for it is mounted in the other mounting hole accommodating some of the old selenium rectifier packs.
2. The lamps were originally soldered in place due to the broken out sides of the lamp wells which can clearly be seen in this pic.......
3. But now can easily be snapped in and out as needed.
4. Waiting for the new Muting Switch to arrive is like waiting for a pot of water to boil........
5. When the RF level control on the 1000A was increased to achieve 20 db of quieting, the control landed on 1.25 db -- once again showing why Fisher Tuners were arguably some of the very best in the business.
Dave
