This tuner is still in use and performs perfectly 4 years since a visit down to Dave's..........
Who makes those yellow caps? When I first started working on tube gear I used orange drops but noticed different brands used in Jim's kits now I see you using the same yellow ones as him. I want to use the best parts and am wondering if the yellow ones are better than orange drops.
Do you know what the brown wires' function is coming out of the metal box? It is not attached anywhere and on other pictures it seems the same? I can not find it in the service documentation.. is it some kind of antenna or should it be connected somewhere?
...... When the replacement caps come in, I will take out the old ones.
Did you ever notice a difference in sound when recapped?
Rob
I'll share with you my experience with my 200-B:
To add to Dave's post...........
Also known as a "GIMMICK". It's TEST POINT 1 as shown in the Service Manual. See below.
Thanks for all the kind words! I'm hardly trying to put my skills on a pedestal, as that's not my style, and the fact that there's sooo much talent here at AK that we're ALL learning something from somebody else all the time!
I do try to go into a unit however, and perform my work while keeping the underside looking as true to the original build as possible -- which is to say that other than the obvious appearance of the modern replacement components used, the installation of them is entirely in keeping with the original build quality of the unit. In other words, the work in fact should NOT draw attention to itself! With Fisher equipment, working to achieve a high level of execution is just one more part of the effort to help preserve the qualities that went into making up what Fisher equipment represents.
The FM-200B is likely one of the very best FM Stereo MPX tuners ever produced back in the heyday of the Stereo/Hifi craze -- virtually as good performance wise and immanently more practical than the top of the line, but studio monitoring oriented FM-1000. It, as well as all of Fisher's products stand proud representing an era gone by, and deserve the finest effort we can give them to help preserve their mark on the history of high quality vacuum tube sound reproduction.
Dave
Dave, great work, as always! I have a couple of questions about this restoration and how these issues may apply to my own work on my FM-100-B. I understand from posts 14 and 15 here that DC bias doesn't play well with non-polar electrolytics. Is that true of non-polar film capacitors?
My apologies if these are overly rudimentary questions, as you know, I'm still learning...
I am wondering if having replaced the 1uF electrolytic in the MPX section with a film capacitor will be an issue. My hunch is that it might be, since the schematic is marked with the polarity orientation. Applying the same matters-if-it's-marked logic, I need a polar 8uF for C65 (located at Test Point 3). Is this accurate?
Extending that logic, I reason that non-polar film caps are appropriate, or at least acceptable for the 2uF (C63) and 0.5uF (C70) capacitors to ground associated with the mono timing circuit. Is that correct?
For reference, my unit is covered in the 40xxx to 49xxx service manual. for the FM-100-B.
I've tried both film and electrolytic for the Composite coupling cap in the MPX section and honestly, I can't tell a difference either way. Either will produce excellent sound quality, with neither having an advantage performance wise. Now whether that's because modern electrolytic caps are so much better (have less inductance being smaller than older types) or not, who knows but you can use either in this location.
Film caps have no polarity and could care less which way they are installed in the circuit, other than the circuit itself possibly being sensitive to the orientation of the cap due to one side representing the outside foil.
In general, a film cap of the correct value can be used in place of any electrolytic cap as long as the darn thing is not so big that it won't fit in -- or if it does, that it's not so crammed into place that it causes circuit interactions that did not exist before.
The problem with using a NP electrolytic cap in a polarized circuit is that a NP cap is effectively made up of two internal polarized electrolytic caps of 2X the indicated value, connected in series, back to back. When a polarizing voltage is placed across this cap then, one of the internal caps has a reverse voltage placed across it, which is not good for its long term health.
Sruddy -- If your FM-1000 is outperforming your FM-200B, then something is clearly wrong with your FM-200B. Both use the same RF front end and therefore the same amount of RF amplification before IF conversion -- and this is only slightly superior to the RF front end used in the FM-100B.
The difference between all three of these receivers primarily lies in the limiting portion of the IF strip. The 100 and 200 use 5 active stages in the IF section, while the 1000 uses 6. In all three tuners, the first two stages are active IF amplifiers, with the remaining tubes all configured as limiting stages -- the 100 and 200 having 3 active limiters, and the 1000 having 4. The differences in the limiter sections amounts to:
1. The 1000 uses a special 6BN6 tube in the 3ed stage of its four tube limiter section. This tube is a Gated Beam Limiter Tube, designed expressly for this type of service. It has the quality of providing effective limiting even with very low input signal levels. As such then, it is a sort of super limiter.
2. The 200 uses conventional tubes in its three tube limiter section, but also uses a voltage doubler circuit in the 2nd limiter transformer (not used in the 1000), to maximize the effectiveness of the last limiter stage.
3. The 100 uses conventional tubes in its three tube limiter section, and conventional limiter transformers.
No doubt limiting performance improves from the 100 to the 200 to the 1000. Honestly however -- and this is not to take away from the 200 or 1000 units at all -- but for all practical purposes, the limiter circuits of the 100 get you 90-95% of the performance provided by the 1000. The 200 gets even closer. This is why I have said that the 100 is the best value in Fisher tuners. I don't have an FM-1000, but have serviced 4 of them. There was certainly no day and night difference between those and my 100 or 200, and in fact, any difference was hard to discern. Again -- I truly mean to take away nothing away from the 1000. It was the cost no object version of their station monitor tuner -- often used for relay service back in the day between stations, with options for a crystal controlled front end, and of course, the 4 tube limiting section -- beyond which no meaningful limiting improvement could be had back in that day. Having as noise free reception as possible was important in station relay use, and so the extra active limiter stage is provided in the monitor, and resulting FM-1000. In the home environment however, the practical differences that will be observed between any of these three tuners in terms of sensitivity and selectivity -- even on weak stations -- will be rather hard to discern in use.
As a result, I would suggest you have a re-look at your 200 to make sure it's not getting short changed!
Dave
