If you have forte 1's, it is very unlikely that the electrolytic bipolar cap is performing anywhere NEAR spec, and if the blue mylar's are in spec, they sound so terrible, there is little reason to keep them in there. I have worked on a few pairs of forte 1's, and those caps leave alot to be desired but the electrolytic on the woofer has got to go.
not knocking anyone that thinks an unmodified forte 1 in 2010 sounds great, but if you do the work on the crossover, there isnt one of those guys out there that wouldnt hear a difference. And its not some audiophile difference, its absolutely measurable and repeatable.
caps have a shelf life and more of the "leave it stock" people really need to get a better understanding of that concept. They dont last forever and in the case of electrolytic construction, they dont last for decades and decades, this stuff needs replacing. Too many people on these boards look at the idea of changing a 20 year old electrolytic in a crossover as a mod or an upgrade when the stark reality of the situation is that its simply maintenance. Changing old forte crossover caps specifically is no more of an "upgrade" than putting new oil in your car. Sadly, many view the difference in sound as an upgrade because the old caps can be so dried and out of spec. An electrolytic turns into a resistor as it dries. You put a new cap in there and thee is huge bass again but its not because of some new super part, its because your old part was no longer a cap... Not all caps are of the same integrity and construction, some will last a very long time, others not long at all. In the case of the forte 1 crossover specifically, there is absolutely no holy grail of capacitor on that crossover and if you carefully clip them out, you can reinstall them if you think youve made a mistake by putting new caps in there...
dont service your equiment if you dont want to, but there are few things as critical in a playback system as a properly set up crossover network on a three way speaker... No matter how good your source, no matter how much you put into an amp, no matter how much youve spent on a turntable, no matter how much youve tweaked your preamp, its ALL gotta go through the four caps on that crossover. You can spend tons of money, $20 for four caps or $8 for four caps and hear an improvement...
Forte is my favorite klipsch, but the few I have heard in the last year with original crossovers are flat and lifeless sounding. It takes only about 15-20 minutes to replace the caps on the original crossover and its really not difficult to do. Many people out there have no idea what they are missing from equipment sitting right there in their living room...
