Mister Pig
Pigamus Maximus
This Barnyard Animals Experience Is
a preference for a single driver speaker with a subwoofer on the bottom end. I owned single driver speakers for quite awhile, and a few years ago tried living with a good three way speaker. That Mourdant Short 880 did some fine things, but I never could get past their ability to fully integrate the drivers, and comparative lack of dynamics. Now these speakers are fairly efficient, and the crossover well thought out, but it still lacks the integration a single driver speaker has.
Now single driver speakers are typically paired with low powered tube or chip amps, as this combo of amplification simplicity plays to the strengths of the speaker. But most high efficiency speakers really only extend down to 50 hertz, which is the case of my Fostex drivers in back loaded horns. So a subwoofer really is required to fill in the bottom end. This is logical plan since the sub is going to have its own amplifier, and brings the power where its needed in the audio spectrum--the bass. The trick is getting a sub thats agile enough to keep up with the full range driver, as a good one is very quick. Typically you run the main speaker full range, and then bring the sub up to fill in the bottom end. That way you don't run the Single Ended Triode amps through an active crossover, which typically will degrade the sound quality of the main amp. In practice this type of set up works well.
Super tweeters are a point of contention. Many feel that they are not needed with a well designed full range driver. There are certain drivers that will extend into the 18K range, and this really is acceptable for audio playback. The mythical 20K plateau doesn't need to be reached. However, its difficult to get a super tweeter crossed in seamlessly, and the good ones can be very expensive. Also you lose the point source presentation, and have a different radiation pattern of another speaker, which compromises the integrity of a single driver speaker. So I don't use them.
Just the take of a barnyard animal on this subject. Got to get off the computer as the farmer is due back from the auction any minute. He doesn't let us barnyard animals into the house to access the computer. We gotta sneak in when he is gone.
Regards
Mister Pig
Regards
Mister Pig
