Brian Beck
I guess a moderator has to weigh-in before these are posted. I sent an email with manual attached to files@akdatabase.org as instructed at http://www.audiokarma.org/forums/showthread.php?t=349095. This is my first such attempt. Not terribly user friendly, but then the price is right...
A couple of things come to mind about your bass issues:
Make sure everything is positioned per the manual, whenever that is posted.
The speakers work best closer to the rear wall than many of us are used to. Start with 10" and see if that helps. They also work well closer together than many people expect, a shallow triangle, not an equilateral one. Make sure that the slots under the bass cabinet face inward, toward each other.
As you see earlier in this thread, the 12" down-firing woofer, although it has a doped pleated cloth surround, can drop out of center with gravity over thirty-plus years. That same surround and the spider can dry up and stiffen a bit with age too. Some people have suggested a heat gun to soften this, but I am wary of that. If your woofers are in bad shape, then once in a while you'll see new-old-stock woofers of the identical type on eBay from a fellow who bought out the RTR driver inventory.
What amplifier and cables are you using?
Room acoustics can be a wild-card, of course.
Finally, although the J is capable of deep and natural bass, it is not a bass heavy speaker. Rather it is neutrally balanced. You won't hear bass unless it's called for by the music. If you're used to the rumble of box speakers with a resonance at 60 to 80 Hertz then the quietude in that band may take some getting used to.
