thesaint
I thought I would get this started after doing as much reading as possible as I could on the
G8&9K. First time in the Sansui forum, so hopefully with expert help we can get this awesome G8000 back playing again!
I wanted to try to eliminate all the try this and try that and give as much useful info as possible before just posting, it doesn't have output.
The unit passed dim bulb test. Turns on and flashes in protection as it should and goes green with audible relay sound! I have checked and cleaned every glass fuse and they all check out good.
Tested dc offset at the speaker terminals, L = +1.3v and R = +71.9v, I know not to worry about this as it can be adjusted later.
Both spk A&B have visual and audible relay engage/disengage when turned on/off.
One of the most common things told is to clean the connected/separated switch. I have done this now 3 separated times on as many days to the maximum. There is no way that switch is not clean. I next dismantled the face and all knobs and went to town cleaning every pot and lever on it. As mentioned repeatedly in past threads, I know I may have to do it again before buttoning it back up when completed.
Went ahead and checked every board with a molex and pins and cleaned them all. They were all really tarnished!
Tapped on relays when tuned to a strong fm station and when using music through AUX, no change.
Tried pre amp out rca to amp in with the switch on disconnected and didn't get anything. Also tried the reverse of that and with the G8000 as the amp, also nada.
In the cluster of the 3 relays, I can hear and see them function. I noticed there is 4th buried in there and do not know what that is for or if I should be able to hear it as you can not really see it.
I hope I have exhausted all the "obvious" and am ready to take some direction on how to proceed with this.
This is from an original owner and it worked fine up until he put it in closet about 8 months ago. It also has never been serviced which seems remarkable to me.
Pre-thanking all that can help someone newish and my first sansui.
