I have been doing even more thinking, and laid down some longer term plans.
Of cause I need to have my speaker boxes fixed up, it is way overdue and desparately needed, I also need a new pair of GAMMA woofers.
But what I really want to do is build a new magnet assembly for my VLD's.
The trail of thought that lies behind what I'll be doing is:
The primary problem with ribbons is the extremely low impedance, so either you need to put a transformer on them, or sacrifice a lot of efficiency and put a resistor on them (well unless you are transmission audio).
What can we do to improve that situation? the answer may be HORNS and Neodymium magnets.
I don't think a Neodymium equipped and horn loaded ribbon tweeter even exists, so why not make one?
Short ribbons with Neodymium magnets and transformers, tend to achieve an efficiency in the 90-94dB/w range, the radial horn from VLD's increase efficiency by another 5-6dB.
So using horns, it should be possible to make a ribbon tweeter with an efficiency in the 95-100dB/w range, if a transformer is used.
I only need an efficiency of 91-93db/w, so removing the transformer, and putting a resistor on them in stead, may end up being a viable option.
If I could make a VERY powerful Neodymium magnet assembly, that is compatible with the VLD chassis... :drool:
The making of this magnet will be quite a challenge, the magnets I need are so powerful that they can easily be considered hazardous materials.
Imagine having to glue several extremely powerful Neodymium magnets together in a "horseshoe" shaped assembly.
I need extremely strong glue, I need frames and "ramps" so that I can slide the magnets in to place, and keep them in place while the glue dries.
I have to be very careful, these magnets will be so strong that pulling them apart after they have come in to contact with one another, maybe be impossible.
If two magnets, or even two glued together clusters of magnets, come too close to each other, they will be sent flying through the air and slam together with enough force to shatter the magnets or even crush your fingers if they happen to be in the way.
I also need learn about simulating magnets, so that I can make an optimized topology, with the parts I have at my disposal.
I can't get Neodymium magnets "made to measure" I have to make due with what is available.
But the goal is to make a fairly efficient, horn loaded, true ribbon tweeter with Neodymium magnets and no transformer.
If I can't attain high enough efficiency, I'll have to find an amp that can drive very low impedance loads, so that I can get away with a smaller resistor on the ribbons, or go completely without a resistor.
This is my dream project, and I can't wait to get started, but it'll be a while.
I need to fix up my boxes and stuff, I really need a fully functional LF system to use with my ribbons.
It'll most likely end up being a GAMMA LA1231 (maybe a 4 ohm one not sure yet, but certainly a LA1231) in a 50-60 liter aperiodic box (nothing fancy, just a basic one).
I'll do a few mods to the LA1231's, I'll remove the dustcap and phaseplug them, like my BK3013A's.
I also want to dampen the basket with felt, and maybe add a thin coating around the middle of the speaker cone, as seen on one of the Bulgarian projects I showed earlier in this thread.
