Adda
Oh there is something I forgot to mention, I have talked about a problem with my DIY capacitor foil ribbons, where they would loose their tension just hours after mounting them, causing a peak around 7.8KHz (as far as I remember) a peak I managed to miss for the longest time, I have focused on the 1-5KHz region when testing.
But I have two types of caps that yield usable foil, one with thicker foil and one with thinner foil.
The thin foil has the peaking problem, but the thicker foil doesn't, but it doesn't sound as transparent as the thinner stuff, and I wouldn't consider it ideal either, but not peaky, still not completely flat though, but good enough for now
So it is possible to make decent ribbons out of capacitor foil, but thinner is not necessarily better.
I still plan on using Howard Dawson ribbons in the future though, unless I can find some high purity aluminum foil of the right thickness, whatever that might be.
