Dandy
Addicted Member
An interesting little promotional video: http://www.youtube.com/watch?v=b9cuvxiqFpE
The 401 doesn’t have quite the same slam as the Lenco but it´s more musical. But I´m still in the process of tweaking the 401.
Bought a Garrard 401 a month ago. I just go it up and running in a heavy mdf-plinth. My first impressions are that it is a little bit better than my previous Lenco L75. I´m using the same tonearm and pick-up (SME 3009 mk II improved and Denon DL103). The 401 doesn’t have quite the same slam as the Lenco but it´s more musical. But I´m still in the process of tweaking the 401.
I have modified the 3009 for improved weight. The extra weight did wonders for the sound of the 3009+dl 103.
I have finally put up my 401 so time for a photo. The plinth is solid Zebra wood. I like the original pale colour, but I have started oiling it to bring out the wood colour more. The arm is a blonde FR64fx and the Cartridge a Kiseki Purpleheart. I will post more when the oiling of the plinth is done.
Cheers,
Soren
My modification are very simple. I used blue tack to "glue" a number of coins together and then i "glued" them to the counter weight with blue tack. I increased the weight of the arm tube by using heat shrink tubing.
The sound of the dl 103 on the Garrard table was lacking top end. So I removed the modifications and installed a Ortofon Bronze. The sound is now more open and dynamic.
English is not my first language so my English can be a little crude.
You may note some scaring on the bottom layer. That is the first attempt where they got it wrong and gave me the cut out and cut up the actual plinth. Luckily they managed to glue it back together.
Unfortunately I can't get Zebra wood here so will have to use another kind.
